Old 03-28-2004, 08:43 PM
rdawg999 rdawg999 is offline
Question Cheapest engine mods for the power?
Hey, Im gonna drop a 302 into a 67 Mustang Ive bought, but I wanted to do what mods I could before I drop it in. I wanted to know what were the best mods for power that I could do on an old 302, for the money. I was hoping to build up to 300hp or more, but looking to spend like 2k, maybe a little more. Thanks!
Old 03-28-2004, 08:54 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
H/C/I!!!! That should reach your goal of 300 easy.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 03-28-2004, 09:11 PM
carnut's Avatar
carnut carnut is offline
Make sure you budget some "whoa" power too. These older Stangs didn't have the best braking systems.
I may be a rat, but I ain't no snitch!
Old 03-28-2004, 09:14 PM
Re: Cheapest engine mods for the power?
True, true.
Old 03-28-2004, 09:34 PM
Sorry, I didnt get the initials, but Im guessing H is for heads, C ? I dont know, and I is intake manifold? If its that easy Ill go for 350 or 400 hp then.
Old 03-28-2004, 09:42 PM
How fast?
So exactly how quick would I run a 1/4 if I had a 4 speed tranny linked up to my 300 hp 302? Im aiming for somewhere in the 13's
Old 03-28-2004, 11:28 PM
SIKCRX SIKCRX is offline
c=cam
2.3L pumpin out 105 stock horses, WHAT NOW BISHES
Old 03-29-2004, 02:35 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Re: Cheapest engine mods for the power?
I doubt you'll see 400hp just by slapping on heads, cam and intake. It will also depend on what carb your running, the fuel system will need to be beefed up, the internals of the motor will also need to be addressed if you want to run upwards of 400 hp, maybe even a R block for saftey. Not to mention that with that kinda of power your going to need a highly tuned suspension to get all that hp to the ground.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 04-03-2004, 04:21 PM
boarder50 boarder50 is offline
If you are looking to spend 2k on parts for your 5.0 and get over 300 hp. Theres a kit through summit racing that im looking into. Gives you a stage 1 cam, twisted heads, intake ...well look at it it goes for like 2k and go to www.summitracing.com and search for stock number:
TFS-k514-350-370 I'm really serious myself about this and with this everything is Trick Flow and works together but does require knowing what the hell your doing. But anyways good luck and if you do get this let me know hoow it works... Im still trying to save the 2k for it. LOL
Old 04-04-2004, 01:51 PM
95 Snake 95 Snake is offline
I think holley's new carbs are the finest for the old mustangs, thats what i got on my 71. Are you running a manual or electric choke?
Old 04-04-2004, 06:19 PM
vette_7t9 vette_7t9 is offline
hmmm, 300hp, mid to high 14s, depending on driver i would say?
