Old 03-28-2004, 08:32 PM
landtoy80's Avatar
landtoy80 landtoy80 is offline
Brake ?
I broke the rear brake line on the Turd.
When the rear brake is out of brake fluid, shoud that affect the front brakes?
The bleeder valves on the front rotors are broken. I has some but very little brakes when the rear line was broken. Should I have full front brakes with the rear line leaking? If so then there must be air in the front brakes. I will get new calipers for the front.
I broke a bleeder in the in one rear wheel cylinder. My easy-out broke off and plugged the bleeder so I blead it by opening the brake line to the wheel cylinder. I will get a new wheel cylinder, do I have to replace both sides or can I replace just one?
After bleeding the at the brake line, I have brakes.
kurt
87 3/4 ton Turdvalanche "Turd" 4x4 TBI 350 (was a Sub)
94 Land Cruiser
Old 03-28-2004, 10:31 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: Brake ?
the broken line will suck in air and screw up the front brakes after a while. you should be fine replacing one cylinder.
