Old 03-28-2004, 07:07 PM
tesla4210 tesla4210 is offline
94 F150 air conditioning
my a/c compressor is not getting power. i've checked and found that the switch is working. ive tried tracing the wires, but it is too difficult. my chilton's manual doesn't include anything to do with the A/C for safety and environmental reasons; they don't even include the wiring in their schematic. isn't there a pressure switch or something in the system? or does someone know where i can get a good wiring schematic? thanks in advance.
Old 03-28-2004, 10:55 PM
precislawn precislawn is offline
Re: 94 F150 air conditioning
Helm has very good factory repair manuals. Here is a list for the f150.
http://www.helminc.com/helm/Result.a...NKA0FCX1JBD866
Old 03-30-2004, 01:28 AM
amac209 amac209 is offline
Send a message via MSN to amac209
did you check the fuse?? there is a pressure switch on the high side near the passenger side of the firewall. try unpluging the electrical connector it should have 2 contacts and jump the contacts with a piece of wire or paperclip. if the ac starts cycling you are either low on refrigerent of the pressure switch is bad. good luck!!
Old 04-02-2004, 07:24 PM
what do you mean by "the high side." I am an electrician, so I am not electrially unaware. but I am not sure what you mean.
thanks,
rob
Old 04-03-2004, 05:36 AM
high pressure, the side after the compressor and condensor the sensor is located of the passenger side of the fire wall.
Old 04-04-2004, 04:31 PM
yeah, i figured out what you meant, and I found the switch. thank you. and jumpering the wires works. it looks like that switch can't be replaced without losing refrigerant, is that true? it probably isn't the switch anyhow, but i was wondering.
thanks again
Old 04-04-2004, 06:19 PM
actually theres a 90% chance the switch isn't the problem. the problem is your refrigerent is low therefore the pressure is too low, the switch is a safety measure to prevent compressor damage. you'll have to get the system recharged. basically all jumping the switch will tell you is that all the other electrical circuits and compressor clutch are working.
Old 04-04-2004, 06:25 PM
There should be a valve stem behind the pressure switch. Once its unscrewed a couple of turns no refrigerant will leak.
