Old 03-28-2004, 06:48 PM
mikeyd84 mikeyd84 is offline
Send a message via AIM to mikeyd84
Question firing order for 2.8 v6
After changing the plugs wires rotor distributor cap, it won't fire. i know what the firing order is and thought everything was put back together the same way it was taken apart. the book says the plugs are front to back on the driver's side, "1,3,5", and on the passenger side front to back, "2,4,6". Is that correct, and where does the number 1 wire go on the distributor cap? Thanks.
Old 03-28-2004, 10:24 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: firing order for 2.8 v6
firing order should be 1-2-3-4-5-6 the cylinder arrangement you have is correct.i don't know where the #1 plug goes but the distributor has a clockwise rotation. if you line up the timing marks on the dampener while cylinder #1 is on the compression stroke the rotor will point to cyl#1. if you remove the #1 plug and stick you thumb over the hole while turning the engine with a socket or by pulling on the belt it will be easy to figure out. good luck.
Old 04-11-2004, 10:21 AM
jscreamerb jscreamerb is offline
Send a message via Yahoo to jscreamerb
numbers 1,3,5 are on the passenger side 2,4,6 are on the drivers side. to verify this look at the engine from the side, one head is further forward than the other. the frontmost cylinder is number one.
Old 09-30-2005, 11:21 PM
kimonagro kimonagro is offline
2.8 L number 1 cylinders is on passengers side
Old 10-01-2005, 05:17 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
1 is on passengers side, and the rotation is counter clock wise, as to where on the dizzy, im not sure, sorry, but the order is 123456
