Old 03-28-2004, 06:54 PM
udelblue udelblue is offline
fuel system upgrades
I have a stock b18b, if i added aftermarket 310cc injectors, fuel rail and new fuel pump would i see sizable gains? thanks in advance for you input
Old 04-02-2004, 04:09 PM
whoneedsvtec whoneedsvtec is offline
Re: fuel system upgrades
depends on what you're trying to do. too much fuel and not enough air could be a bad thing. sounds like you're on the right path if you're trying to go turbo/supercharged. or even nitrous. but you might see gains. the only way to know is to try right? good luck.
my girlfriend calls me a car nut like its a bad thing
Old 04-05-2004, 09:29 AM
matt11583 matt11583 is offline
the fuel system can only give as much fuel as their is air. if you dont do any other upgrades to the engine you wont be able to get much air into the cylinders. if it is turbo charged you will see much greater gains than a n/a. even a supercharger will give you decent gains in hp.
Old 04-08-2004, 08:48 PM
kesnut kesnut is offline
Send a message via AIM to kesnut Send a message via Yahoo to kesnut
your stock fuel system is good for 200 hp, now upsizing your injectors, running 40psi of fuel @7500rpm, you injector will "flow" better... go to hondata.com, click on tech and you will see...
1999 Jetta GLS 2.0 AEG Fuel system problem Probe '97 - '03 3 04-20-2010 11:24 PM
fuel system upgrade for 300awhp... 95DodgeAvenger95 3000GT/Stealth 2 10-30-2007 12:03 PM
Fuel System Upgrade To Produce Major Power???? hawk362 3000GT/Stealth 2 07-12-2007 10:15 PM
Fuel System upgrade question!! Please help!! Sh4rky Integra 4 10-06-2002 04:58 PM
upgrading fuel system for a civic jOYRiDe Engineering/ Technical 4 04-24-2002 12:12 PM
