Old 03-28-2004, 05:14 PM
civicgrl civicgrl is offline
My clutch makes weird noises!
I hear this weird screeching noise when I push my clutch in. It usually makes that same sound but sometimes doesnt. What the hell is that noise? Is it rust? Or is it rubbing against something? I cant figure it out. Please help!
Old 03-28-2004, 07:22 PM
xproductionz's Avatar
xproductionz xproductionz is offline
Send a message via AIM to xproductionz Send a message via MSN to xproductionz Send a message via Yahoo to xproductionz
Re: My clutch makes weird noises!
is it a squeak or something loud...mines squeaked before when i pused it but nothing like a little WD-40 on the joint near the clutch pedal and it was good as gone
Old 03-29-2004, 03:57 AM
Re: Re: My clutch makes weird noises!
It's very loud from the inside AND the outside! It's a squeeking noise as if my pedal is rubbing against something. It's weird! It's kind of embarrassing too! lol! But I will try using some WD-40. My dad said to do the same thing. Thanks for the advice!
Old 03-29-2004, 11:01 PM
ShoofIsLudin ShoofIsLudin is offline
What kind of clutch is it? In my Prelude my clutch screams too. I was told its because of the 4 puck clutch. My clutch will either chatter the front end, or screech
Old 03-30-2004, 09:51 AM
voidplus1 voidplus1 is offline
Re: Re: Re: My clutch makes weird noises!
Does it squeak when you press the clutch pedal down and up? Whether the car is on or off? I think I had the same problem as you a while back, but when I installed a new clutch kit I used gobbs of high-temp grease on all the metal-to-metal parts. Mainly the clutch fork (or whatever it's called).. it teaters or a steel ball thing and on my transmission it was rubbed pretty smooth so I put hella grease there. There's also this springy thing in there that was rubbing against some metal as well, so I put hella grease all over that too. There's been no squeak in my clutch since... I would suggest you do the same, but I dunno if you can lube those parts without removing the transmission. And I can't imagine WD-40 helping much for very long... you need something thicker in there.
Old 03-30-2004, 09:00 PM
my squeak was coming from the joint where the clutch pvitoes on inside the car compartment... just the bolt rubbing the lever thats it... so for me wd-40 was fine.. but if it was deeper than that then yeah, need some thick ass grease
Old 03-30-2004, 11:32 PM
Re: Re: Re: Re: My clutch makes weird noises!
Wow! Sounds so technical! lol! I dont know what the "steel ball thing" is or the "springy thing", or even what the "clutch fork" is! lol! Yeah, it squeaks when I press the clutch in and out even if the car is turned off. But I'm thinking maybe I should just take my car to the shop and see if they can do something for me. I dont think I can afford a new clutch right now! But if I could I would! But I really appreciate your advice! Wish you could help me in person so I could understand better and save money!
~Erica~
Old 03-30-2004, 11:42 PM
cool! Thanks for the advice! I just hope that I'm not wearing anything down each time I press my clutch in. I dont want to make things worse. But n e way, thanks again!
~Erica~
HELP!!! 91 MR2 Turbo makes weird noises HELP!!! mestb16a MR2/MR-S 2 08-04-2004 12:43 AM
98 Prelude making weird noise when downshifting With_The_Quickness Prelude 5 05-24-2003 12:12 AM
axles(wheels,cv) making weird noises jcrx Tires and Wheels 0 11-12-2002 02:09 AM
suspension making weird noise... xXxFLiPKiDxXx Tires and Wheels 4 05-26-2002 03:37 PM
suspension making weird noises... xXxFLiPKiDxXx '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 05-20-2002 01:13 PM
