Old 03-27-2004, 09:09 PM
weirdALJR weirdALJR is offline
Preformance Upgrade 90 GT 5.0
I just picked up my first stang, I got a 1990 Mustang 5.0 GT, pretty much stock with a system and a cowl hood. Im interested in preformance upgrades on a budget. I can't put 10k into the car, but just really wanted some help from you guys to see what I can do to the car to give it a bit more 1/4 mile speed. Just wanna see what is the best bang for my buck on a cheap budget.
P.S. it is a 5 speed manual, seems to allready have updated shifter.
Thanks,
Al
Old 03-27-2004, 09:50 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
1.) Remove intake silencer
2.) Purchase an aftermarket filter setup: i.e. K&N or chrome CAI.
3.) GEARS!!! 3:73's
4.) Full exhaust: Headers, x-over pipe and cat-back.
5.) Underdrive pullies
6.) Some nice rubber. You wont be much faster if you can't hookup!
These are the best starting performance mods for any 5.0. A stiffer suspension will also help you out but may start costing you a bit more.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 03-28-2004, 12:33 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Preformance Upgrade 90 GT 5.0
2.) GEARS!!! 3:73's
3.) Full exhaust: Headers, x-over pipe and cat-back.
4.) Underdrive pullies
5.) Some nice rubber. You wont be much faster if you can't hookup!
Yup Yup. I second the motion!
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 03-28-2004, 05:38 PM
Great guys, thanks for the replies... I'll look into these. If you don't mind could you give me a ballpark estimeate for these upgrades, and maybe which one are more importain to do first. Just to add this is a steet car that I will be driving a lot, I think it may have a upgraded fuel intake, im going to check on that.
Thanks again,
Al
Old 03-28-2004, 08:45 PM
2.) GEARS!!! 3:73's
1.) Free
2.) $125 - $150ish
3.) The gears will cost about $200 w/o install cost.
4.) Exhaust can run many different prices depending upon what you want. At least $500 I'd say
5.) Pullies about $100 or less
6.) Tires will run at least $100 a peice for some good ones.
Old 03-28-2004, 10:04 PM
Removing silencer and adding a cold air intake and pullies all seem like really cheap things I can do myself right away. This is probibly still a total newbi question but do I still remove the air silencer if i add a cold air intake?
Thanks,
Al
Old 03-29-2004, 02:23 AM
HiFlow5 0's Avatar
Stanger
Thanks,
Al
Yes, the silencer is located inside the fender well, on the opposite side of the air filter box. Actually, I wouldn't really recomend a CAI because of it's cost. You can get the same effect by replacing your stock filter with a high flow panal filter by K&N.
-2013 Ford Flex
-1999 Ford F150
Old 03-29-2004, 06:05 AM
john67 john67 is offline
Adusting the ignition timing is also free, except for the cost of the light.
Old 03-29-2004, 11:54 PM
Is this CAI ok for my car? it's cheap at only $50 + shipping andit seems good from auction, checj it out.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEBWA%3AIT
Old 03-30-2004, 12:02 AM
Seems decent, but thats a pretty small filter on there.
Old 03-30-2004, 07:10 PM
I think im going to pick up that CAI tonight, I was examining the STOCK air intake on the car (last owner thought it was cool putting his k&n sticker on it) and I see how it sort of a ram air system intake comming from the wheel well... my question is does adding the CAI kinda bypass the built in air flow setup on the GT. Again this is just a observation on my end but is adding the CAI will give me more HP im picking it up.
Where is oil sending unit 98 Explorer 5.0 Hedhunter Explorer | Explorer Sport Trac 2 02-13-2010 01:19 PM
WTS: 1979, Ford Mustang 5.0 Auto, Coupe, 105,000 orig. miles kevin2e Classifieds 3 12-02-2009 10:49 PM
1986 5.0 turns over but won't start 86_5.0 Mustang Problem Diagnosis 2 06-24-2009 05:50 PM
95 5.0 to 5.7 Motor upgrade cfbeauvais C/K 3 01-19-2009 11:53 AM
Upgrade Parts for 5.0 T-Bird Scott 02 Thunderbird 1 02-20-2003 09:48 PM
