Go Back   Automotive Forums Car Chat > Plymouth > General Discussion
Old 03-27-2004, 08:13 PM
TexRican TexRican is offline
Talking A/C Problem (Grand Voyager 96)
White Smoke was coming out of my a/c vents, then air was warm. I put some freon and it improved but did not last long. Also I noticed that when I turn on the a/c, the fans do not come on. Is this Normal?
I don't have a clue of what could be wrong.
Any help will be deeply appreciated.
Thanks
Old 03-27-2004, 08:18 PM
MrRoscoePC MrRoscoePC is offline
Ac
You have a leaking evaporator core for the A/C in the Dash. The fans are controlled by a pressure transducer and will come on as the engine computer sees fit to do so determined by ac high pressure engine load/temp etc.
RG
Old 03-28-2004, 09:13 AM
Question
Thanks for the info RG. Do you think the fans not coming on is because of the evaporator or the transducer?
Also, I guess I have to remove he dash in order to reach the evaporator. Right?
Thank you for the reply.
RR
Old 04-06-2004, 01:37 PM
A/c
Yes the dash has to come out to remove the evaporator. It is a big job.You could check the transducer connector for rust (located on the smaller diameter A/C line). If the pressure in the A/C is not high enough (ie: empty from leak) then the fans won't come on. To test the fans you could unplug the engine coolant temp sensor and the fans should come on.
RG
