Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 03-27-2004, 09:06 PM
Spinman's Avatar
Spinman Spinman is offline
Changing Rear Air Shocks
Just ordered a set of rear air shocks. The original ones on my '96 have 90,000 miles - and are caked with fluid from leaks.
In any event - does anyone have any info / advice / suggestions on how to properly change the shocks and then test the air level system?
I assume that I need to support the rotor assembly when I disconnect the shocks. Are the monting nuts in the trunk hard to access? Any special tricks?
Thanks for any input...
Old 03-27-2004, 11:11 PM
tjm's Avatar
tjm tjm is offline
Re: Changing Rear Air Shocks
No special tricks that i recall but I do remember wanting a third hand to hold the nut clips for the bottom connection.
I also developed a noise just after replacing the rear shocks and solved the issue by reversing the cup washer at the top (in the trunk). It was a little tough to get the nut on but by squeezing a little more of the rubber mount into the assembly, the noise was gone.
Old 03-28-2004, 11:23 AM
Spinman's Avatar
tjm -
Off to the library this afternoon to read the shop manual....
What do I have to do to access the top nut (in the trunk)? Remove all the carpeting, or is there an "access panel"? There appears to be a cut-out area on the right side with a plastic screw, didn't see anything similar on the left.
Am I correct in assuming that I need to support the lower control arm/rotor assembly - otherwise w/o the shock, the spring will push the unit down too far.
Old 03-28-2004, 11:29 AM
jim56's Avatar
jim56 jim56 is offline
Re: Re: Changing Rear Air Shocks
Originally Posted by Spinman
tjm -
As near as I remember.. I just jacked it up....didnt have to support the
lower control arm........
Old 05-12-2004, 03:20 AM
eoc101 eoc101 is offline
Aurora parts
Hey there, just wanted to let u know, if u need any Aurora parts that are in perfect condition, let me know. Mine's a 96
