Old 03-27-2004, 07:38 PM
flipkid_85 flipkid_85 is offline
How to take out the rear speakers?
Because i blew mine and what size are they?
Old 03-27-2004, 07:43 PM
grand_am93's Avatar
grand_am93 grand_am93 is offline
Banned
Re: How to take out the rear speakers?
there 6 y 9's and u have to take out the back seat were your back layes and after that you pull up the carpet and unscrew themand there are power wires so take those off
Old 03-28-2004, 03:13 PM
Markgase2000's Avatar
Markgase2000 Markgase2000 is offline
Send a message via Yahoo to Markgase2000
the speakers are clipped in so is the cover for them
If its not clean CLEAN IT!!
If its not gleaming SHINER UP!!
If its not appealing BAG IT!!!
Old 03-28-2004, 03:14 PM
Your rear seat backing does fold down , theres a strap in the trunk you pull to release the seat located near the speakers. Fold the seat down and there will be a plastic trim sorounding the edges of where the seat was , it is held on by push pins , remove the push pins to remove the trim peice. Then theres the rear deck cover , since the pins that hold the trim actually hold down the deck cover as well all you have to do is lift the front and pull and the cover comes off. The speakers may have simple snaps that you depress to remove them from the housing and a wire harness clip to remove the speakers from the deck. Hope that helps.
P.S. - dont touch that lil trunk light bulb , it burns instantly
