Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 03-27-2004, 07:30 PM
Dick B Dick B is offline
2001 GMC Sonoma Remote Programing
I am looking to get directions on programing my new remotes for my truck.These are for the door locks.Any and all help is welcomed.Thanks in advance
Old 03-29-2004, 08:41 PM
Stepside_Noma's Avatar
Stepside_Noma Stepside_Noma is offline
Here you go try this
With the driver door closed, hold down the power unlock button on the door panel.
Turn the ignition switch to the ON position.
Turn the ignition switch to the OFF position.
Release the power unlock button on the door panel. The remote control door lock receiver will respond in the following manner in order to indicate that the receiver is in the programming mode:
Locking the doors
Unlocking the doors
Important
All extra transmitters must be programmed at this time. When a new transmitter is programmed, the old transmitters will be deactivated.
Hold down the lock and unlock buttons on the transmitter until the remote control door lock receiver will respond in the following manner:
Locking the doors.
Unlocking the doors.
Repeat step 7 for each additional transmitter.
Turn the ignition switch to the ON position in order to exit the transmitter programming mode.
In order to reprogram the remote control door lock transmitter with a scan tool, refer to Scan Tool instructions.
Memory Seat Recall Programming
Adjust the driver seat to the desired position.
Press the switch labeled SET. A chime confirmation will be heard.
Press the desired position switch labeled 1 or 2. Within 5 seconds from pressing the SET switch, a chime confirmation will be heard.
Press the UNLOCK button on the desired transmitter (key fob) within 5 seconds from pressing the SET switch. A chime confirmation will be heard.
The transmitter (key fob) is now programmed with the desired position switch. Pressing the transmitter UNLOCK button will cause a recall request to be initiated and the seat will adjust to position 1 or 2.
The stored memory positions may be changed without having to reprogram the transmitter.
The transmitter feature is available in all ignition positions.
Memory Seat Recall Unprogramming
Press the UNLOCK button on the transmitter (key fob) within 5 seconds from pressing the SET switch.
Do not press any memory switch or power adjustment for 5 seconds. Pressing a switch will cancel the unprogramming event and the transmitter will remain programmed.
The transmitter (key fob) is now unprogrammed and pressing the UNLOCK button will not effect memory seat operation.
No chime confirmation will be heard when the UNLOCK button is pressed if the transmitter is unprogrammed.
01 extended cab sportside Sonoma ZQ8, 4.3, auto, magnaflow custom dual exhuast, Hypertech pp3, K&N drop in with modified Airbox.
Old 03-30-2004, 07:40 AM
Thumbs up Remote programing
Thanks guys it works.
Old 03-30-2004, 10:47 AM
Re: 2001 GMC Sonoma Remote Programing
glad to help
