Old 03-27-2004, 05:18 PM
JRichter JRichter is offline
Any Suggestions? (ignition)
Any suggestions on a good ignition wire set for my 95 GS (NA)?
And how about replacement spark plugs?
Any info would be much appreciated.
Old 03-27-2004, 05:21 PM
95GSTRaCeR 95GSTRaCeR is offline
Re: Any Suggestions? (ignition)
I used to own a gs and I ran bosch platinum +4's and I really liked the performance.
Old 03-27-2004, 05:53 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Wires - Stock or NGK (I prefer stock)
Plugs - Platinums SUCK IMO, Best one for the NT are the NGK BKR5E-11 (one range hotter than stock). I just recently put these in, like 2 days ago, and I LOVE them. You will feel a difference.
EDIT>>> You can gap these at .05, some people gap them at .042ish (it really wont make that big of a difference) Mine are gapped at .05
For Sale 98 Eclipse GS, 5 spd
Old 03-28-2004, 02:35 PM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
the platinums you dont have to gap,right,i hope not cuz i didn't do it,so the ngk are good huh,got a link ash,maybe ill dump these platinums
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 03-28-2004, 03:17 PM
ashah000's Avatar
You have to gap all plugs. Some come pre-gapped but you should cheak them. If they are the +4 then you can't gap them. But here's a link, just take that part number to a local auto store and they will give them to you.
http://www.ngk.com/results_cross.asp...E-11&x=28&y=12
I got mine for 1.79 a plug.
Import2nr99's Avatar
Import2nr99 Import2nr99 is offline
platinums are usually too hot and don't serve any major performance purpose or increase (from what I hear) NGK and stock are plenty sufficient. If you buy the plugs from autozone or something like that they should already be gapped accordingly. But double check to be sure.
V8's are like tampons, every pussy needs one!
Old 03-28-2004, 11:53 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Stock OEM Plugs and wires run best on stock cars.
