I have to replace the starter on an 88 Excel. Looking in the Chilton manual, it looks as if the engine has to be removed to do this. Is this right? Is there a work-around so that I don't have to pull the engine? Thanks for any help.
this is from auto zone repair info:
EXCEPT SCOUPE--- *Disconnect the negative battery cable. On some models, it may be helpful to remove the battery and the battery tray from the engine compartment during this procedure. Raise and support the vehicle safely. *Remove the engine under cover. Disconnect the electrical harness from the starter solenoid, noting position of wires for correct installation. *Remove the starter mounting bolts and the starter from the vehicle. *Clean the surfaces of the starter motor flange and the flywheel housing where the starter attaches. To install: *Install the starter motor and secure with the retainer bolts. Tighten the bolts to 23 ft. lbs. (30 Nm) for 4 cylinder engines and 20-25 ft. lbs. (27-34 Nm) for the V6 engine. *Connect the electrical harness to the starter solenoid. Install the battery and tray, if removed. *Reconnect the negative battery cable. SCOUPE--- *Disconnect the negative battery cable. *Remove the EGR valve assembly. *Remove the speedometer cable and the heater valve. *Disconnect the starter motor connector and terminal. *Remove the starter motor retainer bolts and the starter assembly from the vehicle. To install: *Install the starter assembly to the engine and secure using the retainer bolts, tightening to 20-25 ft. lbs. (26-33 Nm). *Connect the starter motor electrical connector and terminal. *Install the speedometer cable and the heater valve. *Install the EGR valve assembly and torque the retaining bolts to 7-11 ft. lbs. (10-15 Nm). *Connect the negative battery cable and check the starting system for proper operation. |
Re: Starter on 88 Excel
If you ever have to remove an engine for a starter, time to get a new car...
