Old 03-27-2004, 01:03 PM
jkastner jkastner is offline
Angry Left signal faster than right
I swapped out the flasher unit and it did not correct the problem. My hazzards work fine.... any ideas?
Old 03-27-2004, 02:25 PM
www451oa www451oa is offline
Re: Left signal faster than right
I know this may sound logical, but are you sure all bulbs are working correctly? If you have a bad connection the bulb won't work, and it will make that side flash quicker.
Old 03-27-2004, 08:02 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
One of your blinkers could be out and/or there could be a connection problem. My dad's Astro van did this.
*Under Construction - New sig to debut*
Old 03-28-2004, 04:24 PM
Philo Philo is offline
If you have bulbs with the brake and taillights in one, make sure they are installed properly (if not, one taillight will be brighter). If so, one side will draw more current and will probably change the blink rate. If they are not combined in one, make sure they are the proper bulbs for that truck.
Old 03-28-2004, 04:31 PM
DaviX's Avatar
DaviX DaviX is offline
Send a message via ICQ to DaviX
actually, does it matter to you that much?
Not quite sure though, David.
