Old 03-27-2004, 07:18 AM
Matchmade Matchmade is offline
Lumina APV HELP!!!!!
My 1994 Lumina APV, will not start. It has been running just fine up until today. When I try to start it the starter attempts to start the vehicle and the serpentine belt turns all the pulleys, everything sounds normal except for the vehicle just doesn't start. It has the 3.8 liter v6 and has been solid transportation for 176,000 miles. If anyone has any idea what this could be, I would greatly appreciate any help. I am moderately mechanically inclined and can perform most repairs myself if I know what I'm going after.
Old 03-30-2004, 06:41 PM
tigerfreak36 tigerfreak36 is offline
Send a message via AIM to tigerfreak36
Unhappy 94 apv
hi there, i have a 94 lumina apv as well my service engine light came on the other day and yesterday it died on me three time but started up right away i had a napa mechanic look at at it and put it on a machine, the code said it was a camshaft sensor going bad he said usually when they go out the thing wont start back up again i would have your van put on a machine to findout what it is, u could prob fix it yourself but the mechanic told me there a pain in the but to rplace but it might not be hope this helps. chevy lumina apv loving man
Old 04-07-2004, 10:32 PM
ginterry ginterry is offline
Re: Lumina APV HELP!!!!!
My 94 lumina apv (220,000 miles) did the same thing. Took it to repair shop he put in new timming chain,cam sensor, still wouldn't crank sometime. Took it to another mech. change crank shaft sensor, ignition switch, still wouldn't crank sometimes. After about $1000 spent finally changed the ecm and it runs like a new one. Hope this helps!
Old 09-17-2005, 08:19 PM
patrich9999 patrich9999 is offline
help!!!!!!!!!
i have the same problem that you have had about the 1994 lumina apv cutting out on you after it gets warm and you stop at a traffic light. i really need to know how to fix it. i also need to know how much it cost you. thank you very much.
