Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 03-24-2004, 09:58 PM
zacremacle's Avatar
zacremacle zacremacle is offline
6 speed
will the 6 speed tranny out of an s15 fit onto the other sr engines, like the s13 or s14. I know it is weaker but you have to have a lot of power before it would matter.
Old 03-24-2004, 10:15 PM
PureSXyness PureSXyness is offline
Re: 6 speed
arent s13 or s14 engines KA???
1996 Nissan 240SX
-Injen Short Ram
-Short Shifter
-Magnaflow 2.5 in Catback Exhaust
i swear, i'm working on getting mods
Old 03-24-2004, 10:21 PM
J SPEC SilEighty's Avatar
J SPEC SilEighty J SPEC SilEighty is offline
Send a message via AIM to J SPEC SilEighty
Re: Re: 6 speed
no. s13, s14, and s15 are all chassis codes. many different engines came in them.
and to answer the original question, yes, it fits, but your going to need to use an s15 driveshaft along with an s15 rear differential.
Old 03-27-2004, 01:37 PM
Re: 6 speed
so i guess it's true, you learn something new everyday
1996 Nissan 240SX
-Injen Short Ram
-Short Shifter
Old 03-28-2004, 01:14 AM
240slider's Avatar
240slider 240slider is offline
Re: 6 speed
I think I heard of it being used on a s14 maybe (but don't hold me to that ) but I heard the major problem with the 6 speed is making it fit into the s14 body .because there's alot of fabrication involved
Old 03-28-2004, 02:30 PM
Turbo Thoughts Turbo Thoughts is offline
Send a message via AIM to Turbo Thoughts Send a message via Yahoo to Turbo Thoughts
Re: Re: 6 speed
The s15 trasmission is the same size as the s13 and s14.
Old 03-28-2004, 02:54 PM
Re: Re: Re: 6 speed
true, but the transmission mounts are in different locations. you will need to modify them as well
Old 03-28-2004, 04:47 PM
R.W.240's Avatar
R.W.240 R.W.240 is offline
Banned
6-Speed = Unnessicary/Expensive/Time Consuming
Old 03-29-2004, 05:01 PM
klohiq's Avatar
klohiq klohiq is offline
Re: 6 speed
better gas mpg though I think right? or is the 5th gear not overdrive? Still maybe a bit shorter ratio on 6th than on the stock ka 5-speed...
Maybe useless and pointless...but if you want 6 gears for the cool factor than think about a 2jz swap lol...a bit more expensive and time consuming than an s15 tranny...but you can find supra engines in junkyards here...
