Old 03-24-2004, 09:15 PM
scabahorn scabahorn is offline
04 Silverado Power Plug Removal
How do I remove my left power plug ( cigarette lighter from factory ) so I can install a rubber fill plug like is on the right power plug.
2004 Chevrolet Silverado Extended Cab with bucket seats and a center console.
Thanks
Old 03-24-2004, 09:19 PM
JDeere_Matt JDeere_Matt is offline
Send a message via AIM to JDeere_Matt Send a message via MSN to JDeere_Matt
Re: 04 Silverado Power Plug Removal
I can't help you there, but I too thought about doing the same on my '04. I thought it would look better.
Old 03-24-2004, 10:38 PM
amac209 amac209 is offline
Send a message via MSN to amac209
it's threaded together. if you remove the wires, stick your thumb in the socket and twist the back piece it should come out easily.
Old 03-27-2004, 02:18 PM
My problem is getting access to the power plug. I have pulled out the cup holder and can not get to it that way and have not figured out if I can remove the radio and get to it that way yet.
Old 05-04-2004, 11:12 AM
yakk's Avatar
yakk yakk is offline
The molded plastic component that has the 2 cubbies in it and the 2 plug outlets will pop straight out. Just put your fingers into one cubby and your thumb in the other and pull straight out until the 4 corner clips pop out.
Be careful not to yank too hard as the outlet wires will be strained.
Old 05-04-2004, 08:30 PM
Thank you very much...I knew the compartments had to come out one way or another. I owe you a favor.
Thanks again....Gary
5.3 L silverado spark plug gap icefishingnut58 Silverado 15 03-09-2015 10:03 AM
Accessories Not Getting Power!!!!! Redneckboy360360 Silverado 8 01-18-2010 06:56 AM
1997 silverado slowly lost power mcgyver65 Silverado 8 05-26-2009 08:53 AM
Can't find replacement 2001 Silverado spark plugs markp Silverado 4 03-31-2009 10:02 AM
Removing Silverado power brake booster unit FitzGerald78133 Engineering/ Technical 0 09-03-2005 06:39 PM
