Old 03-24-2004, 08:52 PM
jep5555 jep5555 is offline
O2 Sensors
Service Engine Soon light indicates an O2 Sensor problem according to Pep Boys. I just had one replaced about a month ago. My question is how many O2 Sensors are on a 99 with 5.7 engine and where are they? Is this an easy thing to replace yourself? Does the code readout tell you which sensor is giving the problem?
Old 03-27-2004, 09:01 AM
Jeremy-WI Jeremy-WI is offline
Re: O2 Sensors
There are 4 sensors on that vehicle, two between the engine and the catalytic converters and two after the cats. The code should tell you bank ?, sensor ?. Bank 1 is the drivers side of the engine, and if you follow the exhaust from the drivers side of the engine towards the cat the first O2 sensor you come to is Bank 1 Sensor 1, and bank 2, Sensor 1 would be the closest one on the passenger side of the engines exhaust. The Sensor #2's will be post catalytic. Usually not too hard to replace except that some wiring connectors are near the top of the tranny sometimes and the post cat ones will sometimes be behind a heat shield
Old 03-27-2004, 07:48 PM
Thanks Jeremy! That helps a bunch...
o2 sensor danielgast46 F Series 0 03-15-2009 09:39 PM
Replacing Evap. canister Control Valve, Boost Sensor, and Knock Sensor? raja Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 16 06-04-2007 03:25 AM
Knock sensor and O2 sensor jmmax Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 02-24-2004 11:51 AM
