Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 03-24-2004, 07:11 PM
robz robz is offline
replacing headlight 95 4runner
I know this is dumb but I can't see how to get at the headlights to change the bulb. Do I really have to take the front grill off to get to the bolts to get at the light?
Old 01-02-2005, 12:35 PM
Mark 42 Mark 42 is offline
Headlight Bulb Replacement
You get at the bulb from the back of the headlight.
If I remember right, you have to remove the air cleaner
box on the driver side and the battery on the passenger side.
Then just rotate the bulb assembly (collar?) 1/4 turn
counterclockwise and pull the socket assy out the back.
The bulb is easy to r&r from the socket.
Do Not touch the glass of the bulb.
I always clean them with alcohol just in case someone
at the bulb factory touched the glass.
Brake Light Replacement, 92 4Runner SRS Jakerips 4Runner/GX470 4 05-23-2006 03:43 PM
replacing headlight bulb on a 7 gen whiteracer Exterior | bodykits | Lighting 0 08-04-2003 02:36 AM
How to replace Headlights 94-97 Integras? fredd369 Engineering/ Technical 1 08-02-2003 02:57 PM
Advice on E36 replacement headlights? Chemguy 3 Series 0 07-02-2003 08:49 AM
Replacing Headlights '93 740i yangotang 7 Series 0 02-15-2003 07:45 PM
