Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 03-24-2004, 12:45 PM
German Shepherd German Shepherd is offline
98 3L Chirp Noise on startup
It sounds like two squirrels having a fight under my hood for about 2 seconds when I start my truck. The colder the engine is the more it does it. There are no other symptoms. The problem has gotten gradually worse over the last year.
It sounds like it is coming from the top of engine/intake manifold area.
On the advice of mechanics I have:
I replaced the belt.
I replaced the belt tensioner and its pulley.
I replaced the brake booster.
I have started the truck with the belt off to help isolate the problem.
None of this has made the slightest difference.
Any ideas?
Old 03-27-2004, 12:25 PM
chopper769 chopper769 is offline
Re: 98 3L Chirp Noise on startup
I have a 2000, same problem. Then I had a squeal. I replaced the idler and belt. Fixed it for a while, now it's back and the squeal is continuous. I have no idea either. Just wanted to share your pain. Kinda sounds like the a/c compressor though.
Old 03-28-2004, 04:46 PM
Got some Lube 1 from slick 50, started sprayin' stuff(pulley's and such). I hit the a/c compressor pulley area and sure enough, that's what it is. So I really worked some in there while it was runnin' and the squealing stopped. Until, this morning. Now it's worse. At least I know what the problem area is. Next step... not sure. I'll keep you posted.
Old 03-31-2004, 06:36 AM
It sure sounds like vacuum somewhere
Thanks for the reply.
In my case I have taken the belt off completely and started the engine and still gotten the same noise. This way I have eliminated the possibility of it being the idler, water pump, a/c, alternator, compressor, fan clutch, p/s.
Any possibility it could be a squeaky vacuum-related system or device?
The problem is it won't do it once it's warm so I can't take it to the mechanic unless I leave it over night--which I always hate to do.
Old 03-31-2004, 06:55 AM
IIIIII remeber reading that you took your belt off. My bad. I have the same chirp when cold, plus the squealing a/c compressor. I still have no idea what the chirp could be. I'll probably take my truck to the mech pretty soon, so I'll get back with ya.
Old 04-15-2004, 02:34 PM
bump to top--
Any ideas?
Old 05-14-2004, 09:00 PM
danjake danjake is offline
engine chirp noise
i had a similar noise. the noise occured while driving and idleing. recently had the cam sensor and synchroniser replaced and timed. i own a 99 ranger. apparently the distributor was changed by ford. the noise comes from engine up front near the cab. in my case the noise was hard to locate. an automotive place had 9+hours with no diagnosis only confusion. one first thinks the belt etc. not. removel of belt - noise got louder.
try the suggestion above. good luck
Old 05-18-2004, 02:03 PM
TheRangerOfDanger TheRangerOfDanger is offline
my mom's mountaineer (explorer) had a similar problem
it turned out that her noise was one of the pulleys - it had a factory sealed bearing set in it and it just needed to be changed - it had dried out and was just asking for help. spraying it with lube might not make a difference because 1) it will dry up soon and 2) the bearing may be sealed, so none of the lube will get into where it needs to go.
The other thing to consider is the oil that you use - it could be that you park on a hill or habe a weaker pump or something and it takes a while for the oil to pump into all of the nooks and crannies- -that is not a problem - it just happens sometimes. That would also explain why the problem is more obvious when it is colder; the oil is thicker and takes more time to get moving to the right places.
If it moves and it shouldn't, use duct tape.
If it doesn't move and it should, use WD40.
Old 05-19-2004, 10:40 PM
97chevyman's Avatar
97chevyman 97chevyman is offline
sounds like dry starting to me, are you using a fram oil filter?
2000 ford F-250 4x4 CC auto
1978 F150 4x4, 6 inch lift painted john deere green
Old 12-29-2005, 05:48 AM
jms92 jms92 is offline
Whats the fix for this freakin noise????? It's driving me nuts!!!!!!!!!!
Old 12-29-2005, 07:50 AM
12Ounce 12Ounce is offline
There are many sources for squeaks on the 3.8. Here's a few that come to mind.
1. Belt driven stuff ... including idler pulley and tensioner pulley.
2. Camshaft position sensor (CPS) driver ("synchronizer"). To test, you can remove CPS .. two 7/32" screws ... plug the small screw holes with grease and fill the top of synchro with clean motor oil. Let sit awhile. Crank the engine over if possible. Finally, sop up excess oil ... doesn't have to be totally clean of oil .. and reinstall CPS. This may correct problem ... or, you may have to buy a new synchro. Be sure to scrape off face of CPS sensor with blade or emery cloth ... to eliminate possible "rust dust".
3. Vacuum leaks. Leaks can sometimes be squeakers until heat seals them up a bit.
I assume all the Ford V6's suffer the same ills.
Old 12-19-2009, 04:27 PM
nuckolsk's Avatar
nuckolsk nuckolsk is offline
NUCKOLS
what ever happened with the ac squeel? was it the clutch?
97 Escort-squealing/chirping noise...help! flattop Escort 1 07-01-2004 11:31 AM
99 Accord--cricket chirping noise? katnjny Accord/TSX/Accord Hybrid 0 05-26-2004 11:16 AM
Chirping noise on '99 4 x 4 Duckbill Tacoma 6 04-01-2004 12:27 PM
Chirping noise in 2002 Ford Explorer SeanC78 Explorer | Explorer Sport Trac 2 12-24-2003 01:33 AM
Alarm Chirp Noise soul180 Car Audio 10 04-01-2002 12:03 PM
