Old 03-24-2004, 08:16 AM
Morissette23 Morissette23 is offline
Send a message via AIM to Morissette23 Send a message via Yahoo to Morissette23
Exclamation Help Plz.
Allright ive got a 95 Integra LS. I just got it about...2/3 weeks ago. The passengers side axle went to shit, there was no wheel well, so it got destroyed. When this happened i noticed the car wouldnt go into gear So i replaced that axle. It worked fine for about 2 days. It started agian not going into gear, sometimes it does go into gear but then sometimes it wont. I popped the hood open check the fluids. The clutch fluid is like poopie brown or black. It looks like theres oil in there..as well as were the anti-freeze goes theres some oil in there also. So i bled the clutch line and put some dot3 brake fluid in. and it worked. now im back to not working Anyone have any ideas to what the problem is? Thanks
Old 03-24-2004, 09:11 AM
Re: Help Plz.
nobody?
Old 03-24-2004, 09:51 AM
udelblue udelblue is offline
Re: Help Plz.
when is the last time you changed you clutch?
Old 03-24-2004, 09:52 AM
Re: Help Plz.
your car will run right? just wont go into gear
Old 03-24-2004, 11:17 AM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Re: Help Plz.
are you new at driving a stick?
2002 Acura TL Type S
1991 Honda Crx Si
Old 03-24-2004, 04:08 PM
Re: Help Plz.
the car has the stock clutch, its got now alitte over 124,000 miles on it
Yes the car runs, i can get it into gear sometimes, but the sometimes it wont budge.
And you have a civic so dont talk. no im not new to driving stick
Old 03-28-2004, 02:33 PM
Re: Help Plz.
change the clutch, pressure plate, throwout bearing and resurface the flywheel at a machine shop. you can grab a kit off of ebay for around 250 if you want all the components to replace you clutch. change your clutch!!!
Old 03-28-2004, 06:21 PM
Re: Re: Help Plz.
you sure it would be the clutch?
Old 03-29-2004, 04:52 PM
Re: Help Plz.
only other thing would be your gears but i highly doubt it
