Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 03-24-2004, 12:52 AM
krokuss krokuss is offline
temp light and stalling????
Hello all,
I have a 1999 Jetta Wolfsberg 2.0 4 banger.
The water pump bearing recently went out so I replaced it. I noticed the odometer was at 93,000 so I changed the timing belt at the same time.
The water pump went in good and so did the belt.
Started right up first try and ran fine.
Filled with water/coolant and let run. The Temperature light began to flash but the temp was running cool / normal. It eventually went away, but after 2 days it came back on and flashes. Water level is great and so is temperature???
Any ideas???
Next Problem: After battery strangely died over night. I rechaged it. Now it idles but when I try to drive off the engine completly dies with any load on it??? And the idle drops low for a moment..
Does anyone know what this problem could be? I read a post about the belt jumping a tooth but all the marks are lined up.
Any help would be greatly appreciated.
Thank you.
Old 03-27-2004, 09:20 PM
Well I plugged in the scan tool and it is telling me the MAS is bad. Has anyone else had their MAS go bad?
