Old 03-24-2004, 12:10 AM
camarogirl1 camarogirl1 is offline
Need programming for keyless entry remote for 97 Camaro
I recently had to purchase a new remote key entry for a 1997 Camaro V-6. I do not have the owners manual for instructions. Can anyone give me the instructions to program it? Thanks very much!!
camarogirl
Old 03-24-2004, 08:33 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: Need programming for keyless entry remote for 97 Camaro
hmm, cant remember if there is a button to hold down, but you turn the key to the ON position, and back off, three times. and it will lock and unlock the doors, and pop the deck lid. when it does that, hold down the lock and unlock buttons on the first remote till the locks lock and unlock. then hold down the lock and unlock bottons on the second remote till the locks lock and unlock. then start the car, and makesure they work.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 03-28-2004, 12:37 AM
96CamaroSS's Avatar
96CamaroSS 96CamaroSS is offline
Re: Re: Need programming for keyless entry remote for 97 Camaro
Ok, according to my 96 owners manual and other info online... You turn the key to the on position (not starting the car) then off to reset the system. Then find the fuse box (located on the side of the dash on the drivers side) remove the radio fuse (fuse 15 I think), close your door then cycle the key to on and off (don't start it) three times the locks should cycle lock unlock and pop the hatch. Then after that hold both the lock and unlock button on the keyless until the locks in the ar cycle through lock unlock. The programming is complete. Put back the radio fuse and give it a try. Also you should check to see if your car has factory keyless entry. Check the RPO code list located on the drivers door above the striker. The code AU0 is the code for keyless. If your car doesn't have this code the keyless will not work.
