Old 03-23-2004, 11:31 PM
darkhonda89 darkhonda89 is offline
Send a message via AIM to darkhonda89 Send a message via Yahoo to darkhonda89
re:6al msd ignition
whats up , i was lucky enough 2 score a 6al msd for 10.00 bucks now i was going 2 buy a sport compact msd unit witch is better ??? and anybody know what i need 2 hook it up in my 90 crx si vtec(d16a6 wit a d16z6 head mini me swap ive mantained my si dizzy 88-91 and kept my intake plenum 88-91 also have i fpr insted of the 92-95 fuel rail
thanks 4 helping ...dark
Old 03-28-2004, 10:29 AM
snowman2005's Avatar
snowman2005 snowman2005 is offline
Send a message via AIM to snowman2005
Re: re:6al msd ignition
actually the 6al is better from what i can remember (not 100% sure)and i think that the sport compact doesnt have an adjustable rev limiter just make sure u get a coil and a new cap to instal teh units on ur car. go to msd.com and compare tehm
Old 03-28-2004, 10:31 AM
y do u wana switch heads when the one u have is already vtec. if u dont want taht msd thing ill buy it just in case u dont want it.
Old 03-28-2004, 12:25 PM
BullShifter's Avatar
Re: Re: re:6al msd ignition
If you got the 6AL for $10.00 why spend almost $250 for the SCI with rev.?
Which ever option you choose, MSD modified distrib. cap & external coil should be used, but stock cap & coil will work. Also a good time for new plugs, wires, & rotor. You can see my ignition system in gallery : MSD SCI rev, MSD High Vibration Coil, MSD Cap, MSD wires.
Make sure to disconnect the battery so you don't get zapped.
There is a round black cover on the side of the MSD box, remove it & make sure both wires are cut. Blue / red wires connected = 8 cylinder Red cut = 6 cylinder Blue / red cut = 4 cylinder
Kill switch can be hooked up if you get the violet/green wire adapter. Connect single wire to violet, run to single pole METAL switch, run single wire from 2nd terminal on switch to ground/body.
I think MSD has online manuals @ the website.
