Old 03-23-2004, 11:28 PM
Joseph1082 Joseph1082 is offline
Send a message via AIM to Joseph1082
Dex-Cool... Agree or Disagree?
Do you guys like it... it's in my 02 and chevy said I can't remove or or else I void my warentee. It was in my '96 and gunked up so bad and clogged my whole system... I needed to have the thing power flushed to get it all out, and then put in green. I read online that this has happened to others and there is apending lawsuit. What do you guys think about dex-cool?
Old 03-23-2004, 11:30 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: Dex-Cool... Agree or Disagree?
my understanding is that you only need the dex-cool in vehicles post 1997, i use prestone in my 94, seems to get the job done...
Old 03-24-2004, 09:18 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
if it came with dex-cool, use dex-cool, if it came with green stuff, use green stuff, do NOT mix and match.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 03-24-2004, 09:34 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
dex-cool sucks! commonly refered to as "death cool" that crap gells up and plugs water jackets, and was also responsible for the premature failure of the intake gasket in my sister's 99 grand am, which was loads of fun to change. i flushed her's out and use the green stuff, and no problems since.
Old 03-24-2004, 10:59 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
ive had that simaler problem, but mine started when i added stop leak, right after i put that shit in there it started over heating, it clogged up ther radiator bad, he said it was like cement, got new rad same problem, overheating, i pulled engine out or car, im bored so im jus gonna bulid a mild 350, theres a way to get the water jackets cleaned out them isnt there, what is it called?
Old 03-24-2004, 11:09 PM
well i think the trick to dex-cool is that it only works with itself and you're not at all with anything else. actually i think that if you read the container it says that...
Old 03-27-2004, 12:02 PM
I don't know, but there is this lawsuit against GM, so they must be doing something wrong... also, i'm not aloud to take it out, i void my warantee.
Old 03-27-2004, 03:23 PM
boots03 boots03 is offline
Send a message via AIM to boots03 Send a message via Yahoo to boots03
Dex-cool does suck, i had to flush a friend of mines rad out in his 99 grand prix, and the pan had all of this cunk built up, my 1980 Celica GT that had sat since july didnt even have that much build up in it, i think they should do away with it because that stuff does more harm then good.
Old 03-27-2004, 04:15 PM
I second that notion... I want to ge it out of my car, this is BS, voids my warantee... It better gunk-up while my warantee is still good so THEY can fix it!!
Old 03-27-2004, 04:26 PM
89IROC&RS's Avatar
well from what ive seen at work, the dex-cool only causes problems in certain engines (note that a 99 grand prix was brought up more than once) 97 3.4L engines are also known problems children. but then again rarely does dex cool act up in 96 or 98 3.4L engines. it also has never to my knowledge acted up in any new vehicles, from 2000 and up. dex cool is safe, but in the beginning there was a problem with the castings that allowed it to gunk up like that. and joseph that is where the lawsuit is coming from, people got pissed because it was clogging up radiators after the warantee expired and gm wasnt paying for it, people found out its a common problem, so its GM's fault, hence the lawsuit. oh and 4onthefloor, the dex-cool didnt blow out the gasket, those are just shitty gaskets, they leak on a regular basis, we have a guy at work that does so many of those intakes, that he can do the whole job in less than 4 hours. i think it pays like 8 or something.
Old 03-27-2004, 08:33 PM
4onFloor's Avatar
i know there a shitty gasket, but the rubber was deteriorated from the dex-cool. the reason the leak on a regular basis is because gm later found out that the gaskets have a flaw in the design, now they use steel buttons on both ends of the gasket, and if you ask your mechanic, i think they are torqued to different specs. but ya, your right, and i think it was a little of both that caused the problem. i'd keep the dex-cool in the vehicle as long as it's under warrenty, but when the warrenty expires, flush it out for the green stuff.
Old 03-28-2004, 01:06 AM
96CamaroSS's Avatar
96CamaroSS 96CamaroSS is offline
Dex Cool sucks... My brother bought a 96 SS Conv from a guy who works for Honda Research and Development, and He said that Honda will never use Dex-Cool because over time it gums up the engines and will eat at the aluminum. I guess it is very corrosive. He had removed the Dex-cool from the Camaro when he bought it. This spring I am flushing my radiator and block out and putting normal coolant in.
Old 03-28-2004, 02:10 AM
wierd question, why dont the 3.8(l32/l67) engines have proplems with dexcool, or do they not use it?
Old 03-28-2004, 02:22 AM
4onFloor's Avatar
yet GM techs put that shit back in the vehicles, warrenty'd or not
Old 03-28-2004, 12:48 PM
My whole problem started it my '96 RS... I thought I was going to need a nw radiator. Last summer my car was overheating like a MotherF***er. Checked coolant, it looked like shit, LITERALLY, it was brown chunky stuff. Thank God a power flush ($80) and some good old fashion green antifreeze did the trick. I now hate it and dont feel like having ruin my new 2002. I hope you are right that it doesn't cause problem in newer cars.
