Old 03-23-2004, 11:10 PM
DONTNO DONTNO is offline
What is the best motor for my hatchback?
I'm going to buy a hatchback and my friends are telling me gsr motor and turbo. Don't really have a clue? Is there anything faster?
Old 03-24-2004, 12:14 AM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
k20a or h22a would be faster, but would cost a lot more.
a b16a/b or b18c1/5 should do you well.
Old 03-24-2004, 02:04 AM
Jszy Jszy is offline
Re: What is the best motor for my hatchback?
If you have the money and your looking for speed drop a b18c5 into it. That'll make your hatch preeetty fucking quick.
Old 03-24-2004, 09:43 AM
madmaxEKhatchB18C5 madmaxEKhatchB18C5 is offline
i'm a month away now from the B18C5 route....deposit made already.....perfect for what i want....a damn fast daily driver.....but wouldn't this guy get much more HP if he went the GSR route with turbo or super charger??......all motor is sweet though.....mc
Old 03-24-2004, 07:45 PM
Thanks for all the good Ideas, I'm going to start compairing right now but is there not 1 that is the fastest...I'm going to gut it out and just make it as fast as I can. So is the b18c the best?
Old 03-24-2004, 08:19 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
WOW this is stupid all these noobs telling each other whats better its like hey blind man!!! whats that look like!
Old 03-24-2004, 08:33 PM
projectsilvia97's Avatar
projectsilvia97 projectsilvia97 is offline
Send a message via AIM to projectsilvia97
i would suggest a scooter engine. it's a direct bolt in and you don't even have to worry about any wiring harness, you don't even need an ecu. it's just plug in and play.
Stock 1992 Civic DX hatch
Old 03-29-2004, 03:07 AM
SenseiAccord SenseiAccord is offline
Originally Posted by SiGNAL748
...h22a would be faster....
IMO, never put an h22 in a civic or integra. Not worth it. Gotta get custom mounts and it will make ur car too front heavy. H22 is supposedly 300 lbs heavier than a b series. That added extra weight in the front makes it very dangerous for high speed. Get too much oversteer and may cause ur car to oversteer too much on a small turn and lose control and even crash. Its only good u are doing the 1/4m since u are just going straight. Stick with the b series for civics/integras. H series are only for preludes, accords and CLs.
For ur civic HB i'd go w/ a GSR (b18c1) or CTR (b16) motor. IMO, the ITR (b18c5) isnt worth it. its really expensive for its characteristics. But if u got a lot of money then go with the ITR.
Old 03-29-2004, 11:09 AM
Re: Re: What is the best motor for my hatchback?
O really, wow, that's interesting. cuz i just found these mounts, but they are probably custom because you said that, and you or so knowledgable.
http://hasport.com/shop/product_info.php?products_id=63
Old 03-29-2004, 11:10 AM
o look, some more!
http://hasport.com/shop/product_info.php?products_id=36
Old 03-29-2004, 11:58 AM
T!mmy T!mmy is offline
Send a message via AIM to T!mmy Send a message via MSN to T!mmy
I think that's what I want to do (H22A swap into my 98 Civic) It would be bitching fast and I dont plan on auto crossing or anything so...just a daily driver and my races will be straight. Although how is the h22 for turbo? I would like to turbo it eventually. I'm just trying to decide between H22A and B18C1. Can anyone compare the two?
Thanks
The Dr. tells me too much masturbation is unhealthy...So when is "too much" masturbation "too much"???
Check out our car club site which I made http://www.almostperfectcc.com
Originally Posted by 18c5sol94
we go from a stop he pulls a little on me (only cause i can't keep the wheels on the ground)
Old 03-29-2004, 01:16 PM
Thanks
the h22 basically has 0.4 more liters of displacement, a lot more torque. they have the same compression ratio of 10.6. the h22 has 200 horses, and 161 lb ft of torque. the b18c has 180 horses and 126 lb ft of torque. these engines that i am referring to are the jdm ones. hope that helped.
Old 03-29-2004, 06:30 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
B18C1 (GSR) swap will be the best for cost, speed, and all around handling. If you turbo one of these motors and tune it correctly, you will have one badass car.
Old 03-29-2004, 07:14 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Thanks
if you're going to go turbo, and don't want to do any internal work, go with the b18c1, it has been said that the h22 has weak internals.. besides, the b18c1 swap will be easier to do. if you are willing to drop the cash for internals, and you plan on drag, you might want to look into the h22.. if i were you i would stick with the b18c1
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 03-29-2004, 10:12 PM
boosted331 boosted331 is offline
If you're going turbo, go GSR. If you're going all out, built motor turbo, go GSR. If you're going N/A, go GSR. If you're going all out built motor N/A, go GSR.
The GSR is way cheaper than the ITR motor, which means more money in aftermarket parts to make it faster than the ITR when N/A, and it's better suited to turbo. The only thing the ITR has on the GSR is better gearing.
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
