Old 03-23-2004, 09:18 PM
nickgarry419 nickgarry419 is offline
Post 91 eclipse intake question
I am looking at putting a cold air intake on my 91 eclipse 1.8L non-turbo, my questions are as follows: Do i need to modify the aftermarket intake to hold the mass air sensor found inside of the filter housing, or can i just get rid of this part completely? if I do need this part, then can anyone tell me how to modify the aftermarket intake, so that it will include the mass air in it.
Old 03-23-2004, 09:51 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: 91 eclipse intake question
cut it off with a welding torch in your garauge. and weld it onto your Throdle boddy
Old 03-23-2004, 10:08 PM
this is a ridiculously huge sensor screwed to the inside of the air box, and would not be able to be relocated, either the aftermarket intake must be modified, or the sensor removed all together, i just need to know how to do these things if they'll even work...
Old 03-24-2004, 03:58 PM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
that sucks,good thing i got a 98gs,cuz mine doesn't have one,so my intake took me like 20 min to hook up
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 03-24-2004, 09:51 PM
ahhh you dont need that sensor. pitch it
Old 04-08-2004, 08:45 PM
BlackDeath_Eclipse BlackDeath_Eclipse is offline
Send a message via AIM to BlackDeath_Eclipse Send a message via Yahoo to BlackDeath_Eclipse
well, basically what you do is either, modify the intake to take the sensor (ie the whole lid) somewhere where it can reach (since it has a small cord) or settle for a short ram intake, and use the lid and a K&N filter made for the 1.8L eclipse/talon/laser (if you order direct from K&N you can buy a kit with filter, and specail round ring to help clamp in the filter)
in any case if you get the cold air intake let me know how it works, i've been told by a preformance shop that the engine isnt designed to take in much air, nor put out much horsepower, so you really can't get too much of a gain out of it
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
