Old 03-23-2004, 09:06 PM
kmichael30 kmichael30 is offline
Question fuel filter replacement
Hello group I have a 2001 taurus with 72,000 miles on it and I went out and bought a fuel filter. My problem is how do i replace it i know that it is under the passanger side but how to replace it without breaking the clips on the hose. Not sure where to get them from if i break them. is there any fuel pressure i should worry about when i pull this off any ideas will help i'm a newbie
Old 03-27-2004, 05:22 AM
Bob Gervais Bob Gervais is offline
Re: fuel filter replacement
First you'll need to releive the fuel pressure. You can do this by removing the fuel pump fuse, which is located in a black box on the radiator support. Remove the fuse, then run the car until it dies.
Most new filters come with clips, but if yours did not you should have no problems. I usually use a screwdriver or needle nose pliers to pull the horseshoe shaped plastic clip out. If you don't damage it, they are reusable. If you do damage it, most stores carry them, as well as the dealer. It may not be a bad idea to have a few on hand just in case.
1997 Taurus GL, 1991 Taurus SHO, 1987 GMC Suburban V1500
President, Taurus Car Club of America
Old 03-28-2004, 08:11 AM
Thank you but one more question you say remove the fuel pump fuse and run it untill it dies what if the car has a full tank of gas? dumb question i know i'm a newbie
Old 03-28-2004, 05:31 PM
Cajunblu Cajunblu is offline
Re: Re: fuel filter replacement
kMichael30: No such thing as a dumb question...LOL
By removeing the fuel pump fuse you are shutting down the fuel pump, and by running the engine til it stops you are draining the fuel left in the line....Edit today...you will not drain the whole tank, just what fuel is left in the line going to the carburater...
Hope this helps...
Robert
Old 03-28-2004, 06:53 PM
one last question i looked atg the fuse box and the owners manuel has 2 fuses that has fuel pump relay one of them is the little small clear fuse and the other is a black square fuse that has the ford emblem on it should i remove both of them or which one thanks group for all the help
Old 03-29-2004, 05:40 AM
Either one will do the same job, I usually remove the fuse though. No particular reason why.
Old 03-31-2004, 07:40 PM
Thanks guys for all of your help god bless
Old 06-26-2004, 09:30 PM
LarryKL LarryKL is offline
Allow the car to sit overnight is simple way to relieve the fuel pressure. As mentioned the clips pry off easily with small screwdriver, should also be new ones with new filter anyway.
