Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 03-23-2004, 06:19 PM
ajwilli ajwilli is offline
Stalls
Having trouble with 97 stalling at stop lights. Changed plugs and wires
with new delco plugs and wires. This just started happening any clues
to what this might be.
Old 03-23-2004, 09:45 PM
97 silverbullet's Avatar
97 silverbullet 97 silverbullet is offline
Send a message via AIM to 97 silverbullet Send a message via Yahoo to 97 silverbullet
Re: Stalls
intake manifold, on the opposite side of the intake on your manifold there is a flap the opens and closes, has something to do with backfiring I think, but that part is a seperate piece and there is a seal that can go bad, and what happens is there is a vacume leak which causes the car to stall, but you wont see this problem when driving at a decent speed. this part is expensive but I think if you go to the dealer you can get that seal, That happened to my car, I couldn't figure it out. so after I replaced the intake manifold i never had that problem again. cost me 700 labor + parts, but the part itself was 425 I think.
[On his running for California Governor]
It's the most important decision I've had to make since 1978 when I decided to get a bikini wax.
-- Arnold Schwarzenegger
Politics is not a bad profession. If you succeed there are many rewards, if you disgrace yourself you can always write a book.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 03-23-2004, 09:46 PM
Re: Stalls
intake manifold, on the opposite side of the intake on your manifold there is a flap the opens and closes, has something to do with backfiring I think, but that part is a seperate piece and there is a seal that can go bad, and what happens is there is a vacume leak which causes the car to stall, but you wont see this problem when driving at a decent speed. this part is expensive but I think if you go to the dealer you can get that seal, That happened to my car, I couldn't figure it out. so after I replaced the intake manifold i never had that problem again. cost me 700 labor + parts, but the part itself was 425 I think. i do have my old intake I can take some pictures and show more specifically, just email me at [email protected]
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 03-24-2004, 06:20 PM
BLG66 BLG66 is offline
Re: Re: Stalls
Try Cleaning All The Ground Connections Under Back Seat And Also The Battery Terminals . It Worked For Me On My 95 Aurora, 100k Miles No Longer STALLS At Lights
Old 03-30-2004, 10:46 AM
RickyZ RickyZ is offline
Stalling....................
I've tried all the above "fixes" with no success. Oldsmobile has given up and admits they have no clue. Took vehicle to "experts" who also are clueless. There is another thread that address this problem. Anyone who can resolve this would be quite the hero to me. I'd love some ideas.......
Old 03-30-2004, 11:38 AM
tjm's Avatar
tjm tjm is offline
Re: Stalls
Are ther any other anomolies in performance or starting? How many miles? Does this happen at EVERY stop? Have you checked all possible vacuum leaks? Replaced fule filter and/or pump? Does the transmission shift ok?
Then there is the notorious fuel pressure regulator (although this would have to be an extreme failure)
Give us more information if there is any...
Old 04-02-2004, 04:10 PM
dsatt12 dsatt12 is offline
Re: Stalls
A sticky EGR valve made my 95 do this. There were usually a few surges as it tried to catch itself as the RPMs dropped. There was LOTS of carbon all over the intake manifold area making it somehwhat obvious what had caused my issues though.
