I need a new MAS, and a new bypass valve system, bubble looking thing behind the MAS that it plugs into. Either stock replacements, or aftermarket parts...only cant find any of them, any suggestions? Know where I can find them? Performance or stock MAS, and bypass valve tube behind the MAS. Thanks
Re: Performance MAS!!!
If you have to replace the MAS already, I would go straight to aftermarket upgrades. You can put on the Z06 MAF with a MAF translator, the kit is like 300 bucks or so, but you get a huge intake filter, a 3.75" MAF, and the translator allows you to tune a bit and input which injectors you are running. It is a decent upgrade which I plan on doing in the near future. It's called the LS6 MAFT, you can do a search on 3si.org for the cheapest place to buy it, you may even be able to get a used one there. Otherwise, I found the whole kit on ikonone's sponsor's website
http://www.driven-performance.com/display/206 it includes the ls6 MAF, MAFT, and 9inch K&N filter for $380.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
If you just decide to stay with the stock MAS, www.3sxperformance.com has them, if I remember correctly...
Re: Re: Performance MAS!!!
Does the kit go straight into the current housing and bypase valve? Is the kit a straight install or does it have to be altered to fit into the bypass bubble valve right behind the stock MAS? I need this because of a damn battery short out that caused a engine fire that damaged my stock plastic Y-pipe, my MAS, and some vacuum lines, the vacuum lines and hoses are no big deal, but i desperately need a new Y-pipe and MAS system, the L06 is looking quite nice right now, I just need to know if it while work with the existing parts, and BTW....The bypase valve is fucked too, damn fire, if anyone knows a way or aftermarket part to rid me of that, or a place that has stock replacements, cause i couldnt find them on 3SX....thanks again, appreciate it |
The LS6 MAFT is a direct replacement for the stock MAS, no alteration is needed. The y-pipe I would upgrade as well if you are already buying one. Almost every website out there has the aluminim ones. I would get one, as the stock y-pipe has a tendency to blow off if you boost past 14.5psi. As far as the bypass valve...do you mean the blow off valve, that prevents surges on the turbos when shifting? Because there are plenty of aftermarket BOVs available. If that is what you have in mind, I would upgrade to a closed-loop BOV simply because this recirculates the air back into the intake, rather then releasing it into the atmosphere and causing your car to run rich momentarily. Plenty are available at 3sxperformance.com
the LS6 MAFT is a great upgrade as i have one and can vow for that. If you want on OEM replacement, just find a used one in good working order. You can get one from either a TT or an N/A as they are interchangeable. Proof they are interchangeable, i gave my friend with a VR-4 my old airfilter, and it was still attached to the maft, he looked at the part numbers on top of his and mine, and the part numbers were exactly the same, then he just decided to just use my old N/A one cause it had less miles on it and it works beautifully.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition 1994 Mitsubishi 3000GT SL-TT Automatic - Black 3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods 1994 Mitsubishi 3000GT VR-4 - Black Intake & Boost Controller so far 2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods |
Yea, I already have plans on replacing that stock peice of shit Y-pipe, that fucker got a hole burned through it as well...Im gonna get a nice aluminum one, hell yea. But yea the BOV, i call it a bypass because i just really thought a true blow off vented the gas off completely, and the stock one recirculates it back into the intake. But yea, the stock one on the VR4, it is burned up, and barely holds air, leaks a lil bit, i need a new one, but I really would like to just put a 3SX bov right on my new Y-pipe, but what do I do with the hole where the old blowoff was where the mass connects up...Do i just plug it, or is there a pipe i can purchase for that, or do i just get a new OEM blow off, plug it up, and put the new BOV on the Y-pipe....see what i mean...the 3/S section on DN performence under intake has a little diagram that shows you exactly what im talking about, the part is #7 on the diagram. heres the link http://www.dnperformance.com/intake.htm thanks again |
Thanks |
Sorry first off I am confused, you mean that you need to replace the #7 part on the prior diagram. Because I think that's a stock part, that would need to be replaced. As far as the ls6 MAft, I have been told that its a direct bolt on, I havn't done it yet...its in the future...when I have money.
What exact adapter do you need? what is not connecting to what? This is a site I found with some pics...can you use this to tell us? http://members.aol.com/dwjatwwk/bt.html
[quote=Igovert500]Sorry first off I am confused, you mean that you need to replace the #7 part on the prior diagram. Because I think that's a stock part, that would need to be replaced. As far as the ls6 MAft, I have been told that its a direct bolt on, I havn't done it yet...its in the future...when I have money.
What exact adapter do you need? what is not connecting to what? This is a site I found with some pics...can you use this to tell us? http://members.aol.com/dwjatwwk/bt.html[/QUOTTE That Site uses a Y-pipe mount and has the MAS mounted In a very odd location, the MAFT kit has the instruction saying to simply place the new MAS where the old one was, in the old Mounting location. I already have bought a brand new single piece aluminum Y-pipe, and i cannot afford to do a Y-pipe mount, yet alone by a new Y-pipe. The new MAS needs to go exactly where your stock VR4 MAS is, it needs to fit in that same location according to the instructions. It needs to fit into that Oval shapped opening in the blow off valve connecter piping between the two turbo intake pipes. The problem being, that the New MAS is not an Oval Shape like the stock one, It is much larger, and a Circle, it does not fit. I need an adapter that fits onto the circular new MAS, and runs into a Oval shape to fit into the stock location, something that was not made apparent at the site where I bought it from, and im really pissed that the fact is one of these adapters is around $80 bucks, im pissed |
Re: Re: Re: Performance MAS!!!
dont worry about, i fixed my problem, thanks anyway though!! its under control, sorry about my pissy attitude....bad week, real bad. Ttyl! thanks again
Nah i understand, if I dropped 400 bucks I would want my car working already too. I understand what you mean now. I was just confused. Sorry, alcohol affects thinking...go figure. Anyway, 2 questions..First off, how did you fix it? And secondly, is there a pic of this $80 adapter online, just so I can check it out. Thanks, and glad you got it working.
http://www.dejontool.com/3S.htm |
