Go Back   Automotive Forums Car Chat > Warehoused Archives > Introductions
Introductions Welcome to AutomotiveForums.com. Introduce yourself here so we can get to know you better.
  Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 03-23-2004, 11:41 AM
projectprix projectprix is offline
is 428 same block as 390
I have 75 f150 that i am building into a street rod. it has a new 390fe engine that i ordered, i have called comp cam about a cam and lifters and stuff. I could go with 230 degree with .530" lift and 2400 stall. the complete kit with cam, lifters, springs, and roller rockers is $450. now i want to bore it. I found some edelbrock cobra jet heads for fe (it said "390-428") 75cc at $1200 for the set. now my question is, is a 428cj a 390fe bored out and if not what would a 390 bored .030 over or .060 over be. and should i do it?????
john
Old 08-24-2004, 07:23 AM
kodd kodd is offline
Re: is 428 same block as 390
You can bore the 390 and put a 428 crank in and make it a 410 cid
Old 08-24-2004, 01:56 PM
CaTasHtRoPhE 67 CaTasHtRoPhE 67 is offline
Welcome to AF
86 buick lesabre estate wagon with 70's olds 455 big block engine in need of help kcbuechler LeSabre 29 06-26-2012 09:21 AM
K&W block sealer after failed head swap Bob9646 Thunderbird 4 07-19-2009 09:33 PM
Cracked block? BresRodeo Rodeo | Passport | MU 7 04-25-2009 01:02 PM
cracked block? Feeenxxx General Discussion 1 03-17-2009 06:09 PM
