Old 03-23-2004, 10:16 AM
msteele msteele is offline
Question Civic Suspension or wheel problem
My 1996 Civic has been having problems...
When i reach about 65 mph the car will start to rumble... I had the wheels balanced to see if it would fix the problem but no luck...
Periodically the rumble will go away if I hit a bump in the road or a transition from asphalt to concrete...
History:
* 112,000 miles
* Yes 4 wheel balance was done
* The tire where the rumbling appears to be coming from was patched
Could this be suspension?
Could there be a piece of loose patch in the tire?
Bent rim?
Thanks,
Old 03-23-2004, 10:20 AM
mycivic's Avatar
mycivic mycivic is offline
Re: Civic Suspension or wheel problem
Probably wheel balance wasnt done well. Maybe alignment might work. Is it possible you need new sets of tires?
2003 Honda Civic LX
Mods: Bone Stock
Old 03-23-2004, 12:31 PM
xproductionz's Avatar
xproductionz xproductionz is offline
Send a message via AIM to xproductionz Send a message via MSN to xproductionz Send a message via Yahoo to xproductionz
i had the same problem.. i also had a patched tire and eveything was fine till i hit 50 then it rumbled... got the tires balanced but still no luck.. then i took it to my honda dealer and asked them... they balanced it again and found the problem with the patch causing the unbalance... they said the shop i went to didnt find it because they probably used a lower speed to spin and balance the tire.. as honda spun the tires at higher speeds bacause that was there standard... or so the honda techs tell me
Old 03-24-2004, 12:51 AM
BullShifter's Avatar
Re: Re: Civic Suspension or wheel problem
Could be the wheels/tires. Since a balance was done the first things I would check is upper/lower ball joints & tie rods along with the rest of the suspension parts.
Easy way to check ball joints
Raise the front of vehicle
Grab tire & shake
If you feel any play a further inspection is needed
Tie rods can be checked the came way or with large channel lock pliers squezzing the rod end.
My guess is a upper or lower ball joint.
Old 03-28-2004, 04:35 AM
3rdWrldRcr 3rdWrldRcr is offline
CV axle could be another possibility. The joints tend to wear if the car has been driven hard in turns. After a certain speed you could feel a slight rumble but you will hear a significant popping or grinding noise when you take a turn. Other than that, the only thing i think it could be would be tires (uneven tread, in need of rotating, air pressure).
Bigger Wheels for 91 Civic minoman Wheels/Tires/Suspension 2 05-18-2009 11:31 PM
96 civic suspension problems fakehatch '96-'00 Civic 2 04-04-2006 11:11 AM
03 cavalier suspension/wheel problem? need help!! millrtime Performance 2 10-26-2005 09:51 PM
92 civic suspension problem?? jakked616 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 9 04-19-2005 12:04 AM
