Old 03-22-2004, 11:35 PM
unknownracer unknownracer is offline
Send a message via AIM to unknownracer Send a message via Yahoo to unknownracer
Angry I need help with my 88 camaro
i have a 88 camaro and i am tryg to fix my wiring that is buring my fuses for the lid (lighter and dome lights) the wireing is running from the fuse box to the back of the car and i dont know where to hook the wire up to plz sumone help me
Old 03-23-2004, 12:31 AM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Re: I need help with my 88 camaro
Umm.. Im not too sure what you mean..
So theres a wire running to the back of your car thats fed off of the dome light fuse? and its blowing the fuses? what color is the wire??
Is your rear defrost hooked up and working? The one thing thats coming to mind is the hatch pull down, is that functioning properly?? Pull the back panel off and check the hatch motor and release, and the cargo light
Hope this helps
Old 03-23-2004, 09:06 AM
i have no hatch bc the motor tore to pieces so i took it out and ever thing else works fine
Old 03-23-2004, 11:05 AM
fox 95 s/c fox 95 s/c is offline
when i tried to use the lighter in my 88 i kept blowing the fuse so i tossed it out the window
Old 03-23-2004, 02:45 PM
mike123 mike123 is offline
same thing , when i bought my car i saw teh lighter in teh glove box so i decided to put it in , it shorted out now my horn dome light and lighter dont work , its not a fuse either , i think
Old 03-23-2004, 04:14 PM
DaMoNe6969's Avatar
Mike123 did you check the accessory fuse? (you said you think)
Unknown racer, was there an alarm installed in the car? Are you sure the wiring running to the back in the cause of your fuse blowing problem?
Old 04-27-2004, 10:33 PM
Tmaw Tmaw is offline
Send a message via AIM to Tmaw
Re: Re: I need help with my 88 camaro
Have same problem on 94 camaro, blow a fuse, when push in lighter, or start car, No horn, or lighter, Could care less about lighter, but may need horn
Old 04-28-2004, 01:01 AM
yea its a fuse , that wasnt labeled , its weird cause i "thought" i pulled all teh fuses but yea its the same fuse for your 12v constant(to radio) the horn and dome light and the lighter
Old 04-28-2004, 11:36 AM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
doh...
Old 04-28-2004, 06:40 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
what state are the wires from the hatch motor in?????? if they are bare copper and touching the frame, they may have rubbed through the paint and are shorting to the chassi. blowing the fuse.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
