Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 03-22-2004, 09:45 PM
2000PSI 2000PSI is offline
engine specs
i was just curious as to what the engine specs on a 4runner are im looking at one about 1992 V6 or 4cyl it dosnt really matter i guess just what ever i have the money for
cheers
also does this year have coil springs all round or is the rear leaf and the front coil?
cheers 4 tha help
Old 03-23-2004, 01:00 AM
VTISC007 VTISC007 is offline
Re: engine specs
If I'm not mistaken, it has coils in the rear and it definitely has torsions bars in the front.
Old 03-23-2004, 08:19 AM
Re: engine specs
cheers man, but what are torsion bars?¿?
Old 03-23-2004, 08:40 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: engine specs
The torsion bar, like the leaf and coil, is a spring. A piece of material which when distorted by force (weight) tries to return to its original position (supports the weight). A leaf spring works by resisting bending. A coil spring works by resisting compression. A torsion bar works by resisting twisting.
It fastened at one end to the frame so as not to move during operation. The other end of the torsion bar is fastened to a pivot [the control arm] the other end of which moves up and down as the wheel moves. Think of trying to twist a steel ruler.
Old 03-23-2004, 09:05 AM
Re: engine specs
are they easy to replace to say lift the vehicle and are they more or less expensive than coils and leafs to replace
Old 03-23-2004, 09:50 AM
Brian R.'s Avatar
Resident Chemist
Re: engine specs
They may not need to be replaced to lift the vehicle. They have no height like a spring. It is the point of attachment that is modified to lift the body. They would only need to be replaced to stiffen the "spring rate".
Since they are simpler, they may be cheaper than coils or leafs. Never replaced one to know.
Old 03-24-2004, 03:04 AM
Re: engine specs
cheers bro
