Old 03-22-2004, 08:03 PM
turbo93impreza turbo93impreza is offline
dpfi upgrades? (without mpfi conversion)
i want to keep the dpfi intake on my 89 dx, but i want more fuel for a low boost turbo.
i dont want to run the risk of screwing up the mpfi swap, as i need this car on a daily basis. also the cost would probably be lower, which is always good . i'm good at fabricating stuff, and i just need to know if there is anything out there i can do. i know that you can just plug in larger injectors into the mpfi, so is there anything that will plug into the dpfi?
what about just getting a pressure sensor that will activate a 3rd injector when on boost? that would save gas as opposed to the larger injector route. i guess i could either run one injector at static (wide open) when ever the car is on boost, and just plumb it in before the throttle body or right after or something (this would also be crazy easy to wire up). or i could run 2 smaller injectors and have one run at the same time as each of the larger ones (splice the wires and run them paralelle).
Any ideas?
Old 03-22-2004, 08:05 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: dpfi upgrades? (without mpfi conversion)
okie well you dont wanta mess with MPFI yet you feel ok to boost your car? i mean it can be done but MPFI with or without boost is easier. Not too sure bout other things though
Old 03-22-2004, 09:00 PM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
You actually have the best of the best for the DPFI. There is no other plug and play items you can do it with. Unless turbo or some other little gadget that I have no clue about. Personally, the MPFI swap is the only way you'll ever see the greatest improvement for the D15.
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 03-22-2004, 09:37 PM
optimuscivic's Avatar
optimuscivic optimuscivic is offline
go here: http://www.homemadeturbo.com/turbo_projects/d15b2/
this is how one guy ran a dpfi turbo setup.
As American As A Burrito!
USDM 4 life!
Old 03-24-2004, 08:34 AM
what about running a 3rd injector 100% duty cycle (static) when ever the car went into boost?
Old 03-24-2004, 11:24 AM
89stdzc 89stdzc is offline
Send a message via AIM to 89stdzc
how about forget the 3rd injector or turbo. put in a 75-100 shot of nitro and blow that engine and get a new one....... i swapped a zc in, in 3 days so i didn't have my car for a weekend and monday.
Old 03-24-2004, 12:18 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
Re: Re: dpfi upgrades? (without mpfi conversion)
i'm with Ace on that one. more power to ya if you want to turbo a DPFI d15. however, that doesn't make sense (to me) that you say you're good at fabricating and you want to hook-up turbo but are afriad of messing up MPFI
check this link out...Good MPFI info
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 03-24-2004, 03:42 PM
i'm better at piping than wiring, simple as that. i just havent had good luck at it.
not to mention the added cost of buying the manifold, computer, blah blah blah....
i can make my own citcuits, such as one to run the injector, i just dont like making wiring harnessed etc.
Old 04-13-2004, 12:06 PM
bump
