Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 03-22-2004, 07:33 PM
highrisk highrisk is offline
Coolant Smell
I can smell coolant burning after driving, but can't find a leak anywhere. Sometimes the smell comes in through the vents. Any suggestions?
Old 03-22-2004, 09:54 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: Coolant Smell
Your heater core might be messed up or something. Maybe have it looked at...
Old 06-09-2004, 11:26 PM
MMiller6785 MMiller6785 is offline
Reply to Coolant Smell
I had the same smell. It was the gasket to the themostat housing. Coolant pooled up around the housing and the heat from the engine kept it from ever hitting the ground, so I never noticed it. Replaced the gasket and got a new thermo' and all is well.
Could be it.
Mike
Old 06-10-2004, 07:22 PM
seniorbigs seniorbigs is offline
Re: Coolant Smell
I second the t-stat.
Old 06-11-2004, 01:19 PM
The ORIG. Dig. Oxy's Avatar
The ORIG. Dig. Oxy The ORIG. Dig. Oxy is offline
Re: Coolant Smell
I don't know what year you have, but on my 96 318, the radiator end tanks are plastic.. and those will leak after a time.
Look in the radiator shroud, and the air dam. If the end-tanks are leaking, you'll see some coolant there.
Old 08-05-2004, 01:27 PM
PreRunnerDakota PreRunnerDakota is offline
Send a message via Yahoo to PreRunnerDakota
Re: Coolant Smell
I had the same thing happen to me. I have a 98 dodge dakota, I wound up pulling my Dash out and replacing my heater Core. I know i saw that in one of the replys. Its not fun to pull that dash but it was not to hard to fix the core once the dash was out. Have Fun
