Old 03-22-2004, 06:39 PM
fulanititoo fulanititoo is offline
Question Serious Question
I was reading a forum and I saw something about EVO III o2 sensor what exactly is the o2? Im curious because I recently took out the honey comb inserts int he MAS on my 2g gs-t not only does it idle crappy but i was thinking about replacing it. Also wondering if it could be replaced with an Evo MAS?? Thankz Peepz
Old 03-22-2004, 08:12 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Serious Question
Messing with the MAS is only for 1g cars, you should have left it alone. The EVOIII o2 sensor housing is the o2 sensor housing on the EVOIII (duh). I don't know why you are relating your MAS problem to your o2 sensor housing. In case you didn't know, the o2 sensor housing houses the o2 sensor, which estimates air/fuel ratio.
Old 03-22-2004, 10:24 PM
kjewer1 kjewer1 is offline
AF - Advisor
Unhack your MAS, or get DSMlink. Then your car will run properly again
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-23-2004, 10:32 AM
SO basically i messed it up by taking out the aluminum in the MAS anyway to fix it besides replacing it? Reason I did is a friend told me that it would let more air through and be better for the intake. On top of that I tweaked the little screw on the bottom of the MAS and my car wont start lol help would be appreciated ;-)
Old 03-23-2004, 11:08 AM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
what a moron first put back the honeycomb then untweak the screw until it runs right then sell you dsm and buy a honduh you arent worthy
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 03-23-2004, 12:47 PM
JoeWagon's Avatar
Banned
Hey now, it was a mistake. If your friend tells you something and you believe it, it's not your fault that your friend was full of BS.
Old 03-23-2004, 01:25 PM
Chill little honda dude I need help not smarties, If I still had the honey comb things I'd put them back in.
Old 03-23-2004, 01:51 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Go to a junkyard and get a new one
For Sale 98 Eclipse GS, 5 spd
Old 03-23-2004, 02:33 PM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
yeah,put it back in and then try to get the screw back to the original setting,then see what it runs like, if the problem is still there you will its something else,not what you did,but it probably is
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 03-24-2004, 02:51 AM
AF - Advisor
If you plan to run an AFC or similar, you can compensate with that. Typically takes +30% at 1k rpm, 20% at 2k, 5% at 3k, and zero on up, for the low throttle map. Otherwise, you need to find replacements (many people hack thier mas and may have them for sale if you ask around). Put a WTB up on www.dsmtuners.com
Kevin Jewer
Old 03-24-2004, 08:43 AM
Eclipseoholic Eclipseoholic is offline
i have a 1g and i took out the silencer when u take the silencer out what kind of noise does it make and also i read somewhere that there are 2 honeycombs but i only see one u think someone might of took it out
Old 03-24-2004, 09:01 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Please punctuate, your post made my head hurt.
The silencer removal will let you hear the turbo spool up a bit more, and the intake sucking air.
Removing the LOWER honeycomb on a 1g MAF is not a bad idea...it will prevent fuel cut, but make the car run a little leaner.
I run with the lower chamber removed and a potentiometer in the Bar Temp sensor wire. (Al Blaha MAF ) I don't recommend this as an "early" mod, though.
Kris
2012 Genesis Coupe 2.0t
Old 03-24-2004, 01:12 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
ummm... punctuation remarks aside, if you have it out, shouldn't you know what it sounds like?!?!?! just wondering...
and for the newb that posted this, you should be very thankful you made it in here before you started buying 'deals' off of ebay. or have you already done that? ..lol.. check out some sites for some starter info:
http://www.vfaq.com
http://www.roadraceengineering.com
get a used MAS and that should take care of your issues. think of the o2 housing/sensor like this: it is the MAS of the exhast, where as the MAS is the measuring device directly after the open air and the air filter, the o2 housing/sensor is the last measurement device before exhaust and open air. they are on completely opposite ends of the engine. extremely generaly they serve the same purpose: to measure the gas [not gas as in gasoline, but as in terms of state i.e. solid, liquid, gas] in the system to be interpreted by the ECU.
also check the stickies at the top of the forum for more beginner stuff and info
