Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 03-22-2004, 06:18 PM
92&97ludes 92&97ludes is offline
idle control problems on my 92 si
my car idles up and down even after the car warms up throttle positioning sensor has been replaced and throttle body cleaned still has not helped
Old 03-22-2004, 07:23 PM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
Re: idle control problems on my 92 si
I vote this to be the most asked question here.
Try a search for 'idle', you'll find many posts with people asking similar questions. If you can't find it, ask here again and I'll be glad to help.
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 03-22-2004, 10:06 PM
lude_si lude_si is offline
air valve backed out on the back of the intake manifold. There is a small bolt on the back of the intake take it off there is a small screw inside tighten it do this with the car OFF then put everything back on then start the car and see if u need to do it again
Old 04-06-2004, 11:02 PM
joellthomas joellthomas is offline
There are two holes inside the throttle body (about 8 & 10 o'clock), with the engine running, cover one hole and then the other with your finger. If this clears your idle, then that circuit is the problem. Check your manual for the component.
