check engine lights after changing air filter
Just changed the air filter on my perfect running 93 Camry v6 w/104,000 mile. As soon as I start the engine, the "check engine " light comes on. I double checked that something became disconnected. It was some work to wresle the air box open. Any help? Thanks.
Re: check engine lights after changing air filter
There is a possibility that you may have created a vacuum leak of some sort by accidentally disconnecting a hose from the breather assembly. Also, you could have possibly damaged a sensor that is located somewhere in the area around or near the breather assembly. You'll probably need a code scanner if you can't find any problems with hoses and connections. Best of luck to you, get back with me if you need any more help.
1994 Pontiac Grand Am GT - 3100 V6 1992 Chevrolet Lumina Euro - 3100 V6 1997 Ford Escort - 2.0 I4 "She only squeals when she's wet..." |
Re: Re: check engine lights after changing air filter
You are correct. I had found a disconnected vacume line. Thank you very much.
I'd figured it was a vacuum line somewhere. I'm glad you got it fixed.
