1992 RS Camaro Hood Stuck
Yea my problem is the my hood won't open after I pull the latch. My buddy said to go under the car and look around the radiator for a line and just pull it, I was just wondering if this will work and if there is another alternative way of getting the hood open. Also, the transmission I think is low on fluids because whenever the car would hit 30mph it would jump my RPM Meter to redlineing, is that the fluids or that trans?
Re: 1992 RS Camaro Hood Stuck
well about the hood problem , its prolly the spring on the latch not going back all the way , happened on my car just spray some wd40 or something else , it helped me , umm if you cant get it open you need someone to hold the latch down while you play with the hood , you'll get it eventually
Ive had 4 3rd' gens and have had hood problems with all of them.. Pull the latch (sometimes you havta push the latch back in) and have someone pull up on the hood and kinda giggle it.. it should pop open.. Ive even had one where if you hit the hood in the right place, or push it down a bit then pull up, itd pop open
yup, the best way i have found, pull the latch, walk up, and use the ball of your hand to whack the hood on the front driver side corner, and it should pop open .
Chevrolet Camaro - I enjoy beating the hell out of people http://www.automotiveforums.com/vbulletin/showthread.php?t=68052 |
What I have found, and proved to be true on soo many occasions, is that if something quits working on these camaros(headlight, hatchpulldown or hood for instance) A good swift boot will more than likely fix it!! its always a temporary solution!
on my 91 rs i found that if i pull the latch then hit it obout center ways or a little more to the left about 1 ft. up from the front of the car the hood releases dont know why but it seems to work everytime
aww the subtle art of opening hoods, i think someone should open a class on how to unstick stuck hoods. it'd be a gold mine...
thx guys for your help, what about the transmission problem though?
89IROC&RS that black camaro in your pic looks exactly like mine
