| Maintenance Have questions? Find answers. Help out fellow Supra owners. |
in middle of bhg repair
89 turbo,
does the turbo need to be removed in order to take off the head? the tsrm says to remove it, but i've heard of some that u don't have to, but it will be very heavy. Also, i think the intake manifold is two parts. Does the top part need to be removed? or can it stay on? i'm planning to remove only the parts that need to be removed, but if something is simpler, then i'll do it. thanks for listening. |
Re: in middle of bhg repair
well i would remove the whole intake manifold yall see it will be really dirty if i was u i would get some gas and clean the mudd or old greasse anyways I would clean it pretty well even the 4bolts n the little cover that is n the top of the intake manifold.. yall see that its really dirty too.. but becareful with the gasket make sure there will not brake..
Mmmm i dunno about the turbo thing but i would clean the whole intake manifold if ya plan to do something n it or least just the part that is n the top of the engine(half of the intake manifold.. thanks i have a n/t 89 and i cleaned everything its really dirty man trust me yall be surprise when you see all that.. |
He has a 7m-gte, that means he doesn't have the N/A Y-pipe with the EGR cover. Anyway if the TSRM says to remove something then you need to remove it, it will make the whole thing a serious pain to pull the head/intake/exhaust/turbo off in one peice becuase it will weigh 500lbs. Besides that your going to have to take it all apart anyway to replace the gaskets, you WILL want to replace all the gaskets by the way, 15 year old gaskets get very crusty and brittle. Much easier to do it now while you have it apart than later.
i'm currently at the part of taking off the fuel line. I've already taken everything off but am stuck at that part. the part is on the tsrm online on page EM-37 on number 7 where it says steps to removing number 1 fuel line. my problem is that i cannot remove the bolt on the bottom of the fuel line, each time i try to turn the bolt, the whole metal fuel line flexes like it might bend and break. any tips on this? iv'e been working on and off on this bhg repair for like a week. also, what happened to automotiveforums for the passed 4 days? site has been down right? ok thanks for listening.
Don't worry about it, trust me that line is not going to break. If your really nervous you could always put a set of clamps/visegrips on it to keep it from bending when you undo the banjo bolt. Anyway, yea, AF was down for a few days. Which bolt exactly are you talking about by the way? The only one on the bottom is the union where the hardline meets with the flex hose, that bolts onto the motor mount. You should be taking off both banjo bolts that are on the fuel rail (front and back), then the hardline can stay in the engine bay when you pull the head off.
hey, finally got the head off the block. the head gasket looks kinda messed up, the brass rings around the water holes are all bent. by looking at my pictures on my gallery, are these the reasons for my blown head gasket? i hope so, because i hope that all the good working head gaskets dont look like this. one of the brass rings even fell of when i took off the head. please look at my picture gallery and see if those are the reasons for my blown head gasket? thank you for listening.
Yup, that's where the gasket failed.
once i get the surfaces cleaned up, do i just put the new gasket on? or do i need to put some gasket sealant or something on the head gasket so that it will seal even better. I heard that u shouldn't use that permatex copper gasket spray on the stock head gasket because it isn't metal. also, just wondering, would it work if u put a mhg on on an engine that doesn't meet with the maximum warpage surface, but u use that permatex copper gasket spray. would it still hold? and what if u used stock toyota bolts on mhg? just wondering? thanks for listening.
i got everything cleaned up and am ready to put the head back onto the block. i would like to know where to put the high temp gasket seal on the head and block? thanks for listening.
