Old 03-22-2004, 03:29 PM
Markhaze Markhaze is offline
Question Engine Light
I have a 1996 Taurus LX, with the engine light on.
I checked the code & it was P0401 (Exhaust Gas Recirculation Flow Insufficient Detected). So I took the EGR Valve off and found it clogged with carbon. I replaced the EGR Valve.
But surely something has caused this to happen, could it be the converter? Any ideas
Car runs ok.
Old 05-06-2004, 09:33 PM
sablebomb sablebomb is offline
I had a check engine light that was cure with an oxygen sensor replacement.
Old 05-09-2004, 08:38 PM
irish30's Avatar
irish30 irish30 is offline
Re: Engine Light
The EGR valve recirculates exhaust gases into the intake. Your convertor cleans those gases after burning the fuel air mixture. Don't think your convertor has much to do with a carbon build up. Look more at your plugs and wires. Bad ignition components will give you uncomplete combustion.
Old 05-09-2004, 11:11 PM
harvey43 harvey43 is offline
P0401
I have a 2001 Ford Taurus and my engine light came on with a trouble code of P0401. This means either your EGR is clogged or your DPFE (Differential Pressure Feedback EGR) is defective. In my case the DPFE was defective. There is a procedure for checking the EGR and DPFE, but I do not know what it is. I took a chance and spent $65 at the dealership and replaced the DPFE. It has been 5 months and my engine light is still off. I do not suggest that you take a chance like I did.
