Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-22-2004, 01:10 PM
jcluo jcluo is offline
Check Engine, Tail Light Bulbs, and "R" Reverse Gear Warning Lights On
Hello,
I have a Toyota Camry LE 1999 (4 cycl). It has 108,000 miles and has been running fine so far. Yesterday, when I started my car it showed three warning lights:
1) Check Engine
2) Tail light bulbs
3) "R" reverse gear
Also, the both back-up (Reverse) lights are dead. What could be the problem? Also where is the fuse for the back-up lights? Thanks!
Old 03-22-2004, 05:38 PM
fchanes fchanes is offline
I had the same problem on my 93 Camry. There was a broken wire in the harness that runs from the trunk lid to the main harness. Strip the wires and you'll probably find a broken wire. Mine was the white with black stripe.
Old 04-21-2004, 11:27 AM
qapmaz qapmaz is offline
Re: Check Engine, Tail Light Bulbs, and "R" Reverse Gear Warning Lights On
Check the wire harness at the trunk hinge. It is common for them break
