Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 03-22-2004, 01:00 PM
cvmark84 cvmark84 is offline
98 SSEi battery draining
I have a 98 SSEi that the battery will drain down if the car is left sitting for a day. I used a test light and found that there was some juice being used. I removed all of the fuses under the drivers and passenger dash. I then started removing the fuses under the hood. Here I found two fuses that when removed, would dim the light a little and if I took the other one out, the light would go very dim almost out. The two fuses I pulled are labeled (E.L.C / SPARE) and (C/LTR/RDO/CLSTR/MISC). Can anyone shed some light on these and what I should check next.
Old 03-24-2004, 05:02 AM
markwb's Avatar
markwb markwb is offline
Re: 98 SSEi battery draining
ELC is Electronic Level Control.
Mark
2003 Pontiac Bonneville SSEi, 1999 Ford Escort SE, 5 Speed
IBEW Local 261 Groton, CT
Old 05-30-2004, 09:17 AM
fmkcguy fmkcguy is offline
Try the relay for the power antenna, my '94 was doing the same thing and this was the cause, I pulled the relay out and the problem went away (it's in the trunk near pwr ant. motor)- good luck
