Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 03-22-2004, 12:30 PM
kyleshelley kyleshelley is offline
1970 power window relay?
I have a 1970 thunderbird two door. I'm working on the power windows because they don't work. I've checked the switches and they seem to work ok. Is there a relay for the windows. If so, where abouts is it it located? Is there a fuse box somewhere? Thanks in advance. Kyle
Old 05-25-2004, 09:42 PM
old bird old bird is offline
Re: 1970 power window relay?
If you have not solved this problem I can dig out the wiring diagram. Bob
Old 05-26-2004, 07:20 PM
97Bird's Avatar
97Bird 97Bird is offline
The fuse panel should be under the dash on the drivers side by the steering column if I remember right. I don't think it would be a fusable link coming off of the battery side of the starter solenoid. How did you check the switches? With an ohmmeter or voltmeter? Did you have 12V at the switch?
