| Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems. |
can you use a eclipse turbo for a civic???
One of my friends said you can use a eclipse turbo and manifold and put it on my 95 civic dx... is that true???
Standard or stock whatever you call it you shouldn't have any of that sort on your car... |
Re: can you use a eclipse turbo for a civic???
you can use any turbo you want on your civic and the eclipse turbo is a good one to start with because of its size. im not sure about the manifold but if you can find one at a junk yard or on ebay for cheap then you might as well get it and see if it fits. If it doesnt fit you should have no problem finding a turbo manifold for your engine, afterall it is a civic and it will probably be dirt cheap. You may need to make or have someone make for you a flange to fit the eclipse turbo to the manifold but that will be really cheap.
you said u ahve a dx, if its the older models d-series, u can grab a hf manifold from almost any crx88-90, get a adapter plate and your cooking, the dsm turbo i would recommend is 14b cause it spools quick. But if u have a different engine thne u need a custom exhaust manifold if you know any welders you should go to them. usally you will run into 3 problems, exhaust manifold , o2 housing, and fuel.you should also use 450cc injectors off of a dsm
Ya the turbo you could use but probably not the manifold cuz its made specifically to fit that head and the heads on civics are different than the one on the eclipse
If the car really knew about all this trickery, hed be pretty mad. FOR SALE 2 10" Alpine 1041 Type R JBL BP 1200.1 1200 watt RMS amp Message me if you are interested, make me an offer |
definately not the manifold. but turbo and intercooler yes.
So if I get the SMIC and the turbo from the eclipse how much do u think I would have to spend for everything else? (manifold, injectors, ext..)
Can i use the side mount on my civic?
i saw in a magazine where they fitted it on a crx but you can probably get it in a 5 gen
So how much would everything cost if i were to do this custom turbo kit?
Of Course!
Hell yeah you can attach a eclipse turbo to a civic...even though you have to cut back on the power and psi its pretty much fine. Also you have to make a custom turbo up pipe and down pipe for you car and you also have to retrive a intercooler...which you can get at a junk yard. o yeah your also going to have to dyno tune it or else your car is going to run like shit.
Re: Re: can you use a eclipse turbo for a civic???
