Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-22-2004, 12:13 PM
ShoofIsLudin ShoofIsLudin is offline
Question h22's - does anyone know?
would anybody happen to know if the parts for the h22a1 and h22a4 motors are interchangable (i.e. - connecting rods, etc...)? is there a c/r diff. between a jdm a1, and a usdm a4?
Old 03-22-2004, 10:04 PM
liquidflame8 liquidflame8 is offline
Re: h22's - does anyone know?
they should be but you would have to know if they were the right length for the stroke of the crank
Old 03-23-2004, 10:36 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
well on my b16 that i have, the stock connecting rods would not fit in the type r pistons, so im just guessing you may run into the same problems, try to get matched parts if you plan on upgrading as the borexstroke should be the same for each motor.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 03-24-2004, 12:08 AM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
afaik a1 and a4 are exactly the same EXCEPT for the a4 (97-01) having a 10.6:1 ratio thus creating "200hp" as opposed to the a1's (92-96) 10.0:1 ratio making "190hp"
btw..there was no jdm "a1" - the jdm h22's never came with a revision number. All jdm h22's are stamped "h22a"
Old 03-24-2004, 09:35 AM
You are right...I overlooked that. Thanks for your help!
