Old 03-22-2004, 12:53 AM
mng13 mng13 is offline
silverado brake failure
99' Silverado, 4.3, 4x4, when I approach a stop sign etc. occasionally the brake pedal will kinda stutter but the truck keeps rolling, like it has no brakes, very scary. Otherwise the breaks work fine.
Any advice would be appreciated/
Thanks,
MNG
Old 03-22-2004, 01:16 AM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: silverado brake failure
sounds like a bad abs module. i'd get a dealer to diagnose it first since these things are very expensive
Old 03-22-2004, 07:31 AM
Sonny01's Avatar
Sonny01 Sonny01 is offline
The problem is addressed in Service Bulletin 02-05-25-006A and an easy fix if you can take your front wheel, caliper and rotor off. The ABS sensor attracts metal flakes and the hub it fits into gets a rust buildup. I tested both secsors and found the left one to be low in output voltage. It was cleaned and now all is well. Any GM dealer will have access to the bulletin. I would pull up to a stop light or another car etc...the ABS unit would buzz and my brakes would release. Pretty scary.
Sonny
Old 03-22-2004, 08:48 AM
piley piley is offline
Thanks for the info Sonny01.
I pulled into my driveway yesterday and almost went right through the garage door. The driveway was bare and dry but when I went to stop the ABS kicked in and the truck surged forward. I stopped within inches of the door.
Good to know it's a simple fix. How exactly do you clean it? Do you just have to brush the flakes/rust off?
Paul.
Old 03-22-2004, 11:55 PM
Sonny01's Avatar
After you get the sensor off just about any cleaner will do but the casing is some kind of black plastic so be careful you don't melt it. The whole problem is you can't get to the sensor very easy to use a tool until it comes off. If you have an AC volt meter you can test the sensors first. You would need to splice into the wires, raise the truck and spin the tire. My left one was .125 and the right .360. .350 is the minimum.
Sonny
Old 03-23-2004, 11:37 AM
Thanks again Sonny.
I'll give it a go.
Old 03-23-2004, 04:57 PM
karen brannum karen brannum is offline
I have a 94 chevy silverado, that keeps locking up the brakes. I have cleaned the abs sensors, but it still keeps them tight and i can feel them pulling down on the system. help please
2000 5.3L Silverado brake system is weak but everything is new Silverado_Dude Silverado 1 06-14-2010 07:12 AM
95 silverado abs light is on and smells like brakes joseriverasg Silverado 2 12-21-2009 10:15 AM
02 Silverado shakes when braking. kegster Silverado 17 07-17-2009 07:57 AM
2000 Suburban Brake Failure sk29 C/K 8 04-26-2004 09:34 PM
Brake` Failure` please` help FuLL BLown STD '88 - '91 Civic | CRX | Wagon | Shuttlee 6 10-30-2003 07:28 PM
