Old 03-22-2004, 12:16 AM
crxtacy crxtacy is offline
91 hf
aight, im looking at a 91 hf for 1800, maybe 1300. i plan to put a b series engine in it. either b16 or ls b18. my friends and my dad can help me with the swap, except for the wiring. a friend told me that the axles wont fit on the hf and they i would have switch the discs with the si or dx. is that true?
i know ALOT of people have b16's. im just worried about getting one thats all fucked up and having problems. anyone have any advice or a newb to the honda sceen.
Old 03-22-2004, 12:18 AM
90civicracer's Avatar
90civicracer 90civicracer is offline
Send a message via AIM to 90civicracer
Re: 91 hf
HF is a great body for a swap. Lightest 2g CRX and great for making quick. You should be able to find an hf for that price easily, but i am not sure about your question towards the swap. Welcome to the boards and enjoy your stay (god i sound like a flight attendant).
***90 Civic EX 4 Door***
Ace$nyper: yea it did woo woo 4500 posts i should be ashamed *kills self*
90civicracer: haha you killed yourself you got
Ace$nyper: OMFG LOL that might be the funniest thing you EVER posted
bwhahahaha
Old 03-22-2004, 12:20 AM
91lxdreamer's Avatar
91lxdreamer 91lxdreamer is offline
Send a message via AIM to 91lxdreamer
Yeah youll need new axels, 90-93 teggy axels will do, or if youre really gung ho, they sell racing axels for the b16, but prolly not worth your money. As far as the brake swap goes, never heard of anything like that so far...I think your friend might be mistaken
Official AF Primer Crew!
Updated 1-23-05
For sale: Stock 4-door corner lights. 13" stock wheels with 6 month old tires.
Old 03-22-2004, 12:39 AM
Re: 91 hf
im not going all crazy. im lookin for low to mid 14s. no boost or anything. so the integra axles with be fine.
whats everyones opinion of the b16 compared to the ls b18? or b18 with the low geared b16 trans?
Old 03-22-2004, 12:15 PM
lilol89crx lilol89crx is offline
Re: 91 hf
you will need dx or si hub assemblys. the hf spline count is 23 as opposed to dx/si being 26. basically hubs, rotors, calipers and ur set.
Old 03-22-2004, 01:08 PM
Re: 91 hf
how much/hard woudl that be? so would it be worth getting the hf for a future b series swap. for now, it will be a daily driver once i sell my car and get money for the swap. i just need something older for insurence reasons. so i figured the lighest, 63hp crx would be perfect on gas and best host for a swap. but will it be easy to switch the hubs? so dx and si will both work?
Old 03-22-2004, 01:23 PM
Mojoe Mojoe is offline
Re: 91 hf
Hub and steering knuckle swap is pretty easy...check out the manuals for removal/install if you need alittle help. I have a 91 HF with B16 swap and had to do the same. Ordered a complete b16 package from hmotorsonline (motor, tran, ecu, harness, Teg axles and intermediate shaft)and they threw in a pair of hubs & knucks for $50...even had calipers and rotors still on them. I did put new cals & rotors because their fairly inexpensive. I also had to get 14" rims because the stock 13's wouldn't clear the bigger caliper.
Old 03-22-2004, 01:50 PM
Wow, I learn something new just about every day. I didnt know you needed to swap the brakes and stuff...good to know. Thanks lilol89crx for not flamin, and just givin instruction, I appreciate it. Thanks for the info too
Updated 1-23-05
Old 03-22-2004, 03:16 PM
viridion viridion is offline
Send a message via ICQ to viridion Send a message via AIM to viridion Send a message via MSN to viridion Send a message via Yahoo to viridion
Re: 91 hf
I'm putting an LS into my 90 hatch and i just used integra front suspension..the whole thing minus struts cause i got coilovers
that way i know the axles will slide right in
Old 03-22-2004, 04:34 PM
Re: 91 hf
flaming is gay and uncalled for. were all here to help each other and the only way thats gonna happen is if were adults about all of this a little sarcasm is nice here n there though
they may slide in properly and bolt up fine but the teg front knuckles on ef/ed upper control arms tend to end up with more neg camber than the si/dx knuckles. however u did say u used everything but the struts so let us know how it works out as far as camber is concerned.
Old 03-22-2004, 05:14 PM
Re: 91 hf
dumb question but whats an intermediate shaft
Old 03-22-2004, 05:57 PM
Re: 91 hf
http://cayotic.com/Axles.html
Old 03-22-2004, 09:03 PM
Re: 91 hf
ok. so what axles would i have to use if i put in a ls with a 90-93 integra tranny?
Old 03-23-2004, 04:05 AM
Re: 91 hf
also, what do you all recomend doing to whatever engine i get for a "refreshing" waterpump, timing belt, clutch. anything else? plugs and plug wires?
Old 03-23-2004, 01:05 PM
Re: 91 hf
90-93 teg axels....... if u got tha cash i recomend a full rebuild b4 installing. granted your gonna have to go through a break in procedure but hey IMO it will be better in the long run
