Old 03-21-2004, 10:28 PM
kuminkoskia kuminkoskia is offline
S10 Blazer Cat
I have a 1995 S10 Blazer 2wd, with a 4.3 engine, The catalytic converter has been rattling inside from time to time when it is running. Today I lost almost all power, I think the catalytic converter is blocked. Has any one ever experienced this problem.
Old 03-22-2004, 11:18 AM
MGoBlue102 MGoBlue102 is offline
Re: S10 Blazer Cat
yes, the rattling is definitely the cat, the porcelain breaks up inside when its old and causes blockage of exaust. Loss of power is normal, definitely have the cat replaced. Keep a close eye on the weld when the company replaces the cat, it is very hard to weld the top of the pipe since there is only about a 1 inch space between the body and the pipe. If the company doesnt weld it right, you will have air leaking before it gets to the cat and cause all kinds of false emissions reports with your sensors. If your in a state that does emissions testing, you may not pass that test either.
Old 03-22-2004, 08:59 PM
Cat it was!
Thanks MGo Blue,
I had the cat replaced and bigger than day, the old cat insides was loose rattling around like a big deformed marble in a soda can, when it gets pushed to the rear of the cat by the exhaust, low and behold it blocks the exhaust... I had the engine put on a scan and the EGR came up faulty, had that replaced, now the old Chevy purrs like a kitten and throttles up the RPMs like a champ, nice call, thanks again..
Cruising again in California.
Old 03-22-2004, 09:02 PM
Do cats go bad?
Do cats go out after so many miles or is it because of the faulty EGR?
Old 03-23-2004, 04:41 AM
cobra1 cobra1 is offline
they general dont just go bad.
if you run over something that would strike the cat hard enough, it can break the catalyst substrates.
an improperly tuned or misfiring engine is the cats worst enemy however. raw gas from a rich running/misfiring engine burns in the cat, causing it to operate at a much higher temperature than intended. this causes the substrates in the cat to melt down , which then causes blockage.
Old 03-23-2004, 08:34 AM
Cat 101
Cobra, thanks for the brief on the notorious catalytic converter. I as I am sure others have, know where it is located at however the nuts and bolts of the mechanism, are all Greek.
Thanks again, she is running like a spring bride, with the new cat and egr valve.
Old 03-27-2004, 06:20 AM
Re: S10 Blazer Cat
I forgot about that, right after my cat went out, I got egr readings too, had to replace the egr valve also, thank goodness the egr valve is right on top of the engine and can be done very easily. I think there is some relationship to those two things since one needs to be replaced right along side with the other when one goes bad.
94 s10 blazer 4wd 4dr 4.3 parting out chevyshitsonford Classifieds 9 10-27-2016 09:35 PM
92 S10 W Blazer 4WD Fuel trouble LarryGLack Problem Diagnosis 15 04-04-2010 08:59 PM
90 s10 blazer 4.3L stalling, erratic idle.. please help! gunner0352 Problem Diagnosis 6 09-18-2009 08:31 PM
94 s10 blazer 4.3 high oil pressure chevyshitsonford Problem Diagnosis 4 03-08-2009 09:11 AM
starter from 86 s10 blazer fit & work in 88 s10 blazer help pleEASE!!!! juzdose S-10 1 12-20-2003 06:36 PM
